tandrot8
Errors in 7.6 and 7.7 OS
Tue Jan 24, 2023 11:27 am
Hi !
The issue that I run into is this:
I logged in the router using Winbox. After logging, I couldn't see anything if I selected, for example, IP>Firewall to see the rules. The window was blank but I was able to see the menu on the left side and reboot the router. After logging back everything returned to normal.
This happend twice, on both v7.6 and v7.7 running on a hAP ac^3.
Below is what was displayed on terminal:
jan/19/2023 18:34:34 system,error,critical router was rebooted without proper shut
down, probably kernel failure
jan/19/2023 18:34:34 system,error,critical kernel failure in previous boot
jan/19/2023 18:34:34 system,error,critical out of memory condition was detected
jan/20/2023 09:32:00 system,critical,info ntp change time Jan/19/2023 18:34:56 =>
Jan/20/2023 09:32:00
jan/24/2023 04:26:34 system,error,critical router was rebooted without proper shut
jan/24/2023 04:26:35 system,error,critical kernel failure in previous boot
jan/24/2023 04:26:35 system,error,critical out of memory condition was detected
jan/24/2023 09:34:27 system,critical,info ntp change time Jan/24/2023 04:26:56 =>
Is this a memory or kernel issue or is it a different kind of problem?
Thank you.
zandhaas
Re: Errors in 7.6 and 7.7 OS
Sat Jan 28, 2023 10:09 pm
I have the same issue on my HAP ac2 running RouterOS 7.7 and zerortier active.
Anyone an idea what is wrong here?
holvoetn
Sat Jan 28, 2023 10:13 pm
Export config
Netinstall
Reapply config
Then see if it happens again.
Users browsing this forum: GoogleOther [Bot] and 119 guests
