Admin
Change word in comment
Tue Jan 24, 2023 12:15 pm
I would need a script that would change one word in the comment, which is always the same, while the other words should remain unchanged.
like this
Roterboard now
set [ find default-name=sfp1 ] comment=lalalal_WORDBEFORE_lalalal name=Gi0/1
set [ find default-name=sfp2 ] comment=vavavav_WORDBEFORE_vavavav name=Gi0/2
set [ find default-name=sfp3 ] comment=dvdvdvd_WORDBEFORE_dvdvdvd name=Gi0/3
Roterboard after script
set [ find default-name=sfp1 ] comment=lalalal_WORDAFTER_lalalal name=Gi0/1
set [ find default-name=sfp2 ] comment=vavavav_WORDAFTER_vavavav name=Gi0/2
set [ find default-name=sfp3 ] comment=dvdvdvd_WORDAFTER_dvdvdvd name=Gi0/3
The script should search for the interface with the keyword "WORDBEFORE" in the comment and change it to "WORDAFTER"
Thanks for your help :)
rextended
Re: Change word in comment
Tue Jan 24, 2023 5:22 pm
and what is needed? it's easy!
rextended
Tue Jan 24, 2023 5:44 pm
search tag # rextended Search and replace function:
:global searep do={
    :local input [:tostr $1] ; :local search  [:tostr $2] ; :local replace [:tostr $3]
    :local start -1 ; :local tmppos 0 ; :local sx "" ; :local dx ""
    :while ([:typeof [:find $input $search $start]] = "num") do={
        :set tmppos [:find $input $search $start]
        :set sx     [:pick $input 0 $tmppos]
        :set dx     [:pick $input ($tmppos + [:len $search]) [:len $input]]
        :set start  ([:len "$sx$replace"] - 1)
        :set input  "$sx$replace$dx"
    :return $input
How to use that function:
example code
/interface
:local searchthis "WORDBEFORE"
:local replcwthis "WORDAFTER"
    :foreach item in=[find where !dynamic and type="ether" and comment~$searchthis] do={
:put [get $item comment]
        set $item comment=[$searep [get $item comment] $searchthis $replcwthis]
Admin
Tue Jan 24, 2023 8:13 pm
I tried to run script but result is empty comment...
What i did wrong?
Tnx
:global searep do={
    :return $input
example code
/interface
diamuxin
Tue Jan 24, 2023 8:56 pm
Check if these three conditions are met:
BR.
Admin
Tue Jan 24, 2023 9:28 pm
interface prin where !dynamic and type="ether"
# NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
Gi1/1 ether 1500 1598 9498 D4:CA:6D:41:EC:C0
1 S Gi1/2 ether 1500 1598 9498 D4:CA:6D:41:EC:C1
2 S Gi1/3 ether 1500 1598 9498 D4:CA:6D:41:EC:C2
3 S ;;; lalalal_WORDBEFORE_lalalal
Gi1/4 ether 1500 1598 9498 D4:CA:6D:41:EC:C3
4 S Gi1/5 ether 1500 1598 9498 D4:CA:6D:41:EC:C4
5 S Gi1/6 ether 1500 1598 9498 D4:CA:6D:41:EC:C5
6 Gi1/7 ether 1500 1598 9498 D4:CA:6D:41:EC:C6
7 Gi1/8 ether 1500 1598 9498 D4:CA:6D:41:EC:C7
8 Gi1/9 ether 1500 1598 9498 D4:CA:6D:41:EC:C8
9 Gi1/10 ether 1500 1598 9498 D4:CA:6D:41:EC:C9
10 Gi1/11 ether 1500 1600 9500 D4:CA:6D:41:EC:CA
11 Gi1/12 ether 1500 1600 9116 D4:CA:6D:41:EC:CB
12 Gi1/13 ether 1500 1600 9116 D4:CA:6D:41:EC:CC
BR.
rextended
Tue Jan 24, 2023 9:36 pm
you paste both function and example on terminal, or only the example that use the function?
If you do not paste first the function, how to use it?
You have blank results also with this?
:foreach item in=[/interface find where !dynamic and type="ether" and comment~"WORDBEFORE"] do={ :put [/interface get $item comment] }
Admin
Wed Jan 25, 2023 11:25 am
With this code nothing happens
/interface
I can give you access to one routerborad if you want to try?
rextended
Wed Jan 25, 2023 12:09 pm
You read what you quoted?
You must use both script at same time, or why I write the function over the example, uselessly?
Admin
Wed Jan 25, 2023 1:48 pm
Ahh, sry... i now undstand the script, it works! Thanks a lot!
Users browsing this forum: yogsoncdw and 88 guests
