gezir
bandwidth speed limit for range ip ( from 20 to 80)
Tue Jan 24, 2023 5:31 pm
I have mikrotik router and I need to do bandwidth speed limit for range ip
For example for '192.168.88.20 to 192.168.88.80' I need set download set 8MB and Upload 5MB
How can I do ?
erlinden
Re: bandwidth speed limit for range ip ( from 20 to 80)
Tue Jan 24, 2023 5:36 pm
gezir
Tue Jan 24, 2023 5:52 pm
This not for specific range ips
akakua
Tue Jan 24, 2023 6:26 pm
you can specify a mask instead of an address. for example 192.168.88.0/26, so the queue will cover the range 192.168.88.0-192.168.88.63
gezir
Tue Jan 24, 2023 8:23 pm
No , I need for IPs '192.168.88.20 to 192.168.88.80'
holvoetn
Tue Jan 24, 2023 9:11 pm
Multiple simple queues with appropriate mask then.
Combination of them all should cover your range.
Look for solutions, not problems.
Jotne
Tue Jan 24, 2023 10:09 pm
Since you are using decimal number in a hex number settings, you need multiple subnets.
Better if you setup range using 16/32/64/128 etc, not 20,80.. Then one subnet would be needed.
This will cover from 20 to 80.
192.168.88.20/30 20-23
192.168.88.24/28 24-31
192.168.88.32/27 32-63
192.168.88.64/28 64-79
192.168.88.64/32 80
Use Splunk> to log/monitor your MikroTik Router(s). See link below. :mrgreen:
MikroTik->Splunk
Users browsing this forum: AtisE and 81 guests
