Rohit991
(Urgent) Unable to access mikrotik
Tue Jan 24, 2023 7:34 pm
Hello experts,
My Mikrotik olt firewall has only API (for radius server) and winbox enabled.
Today i was setting my IP in winbox firewall. so that only this IP can access Mikrotik olt via winbox.
But I have added the wrong IP. and now I am unable to access it. Error: Connection refused.
Tried to connect via Mac address, still unable to access it.
Is there any way to access my OLT without resetting it?
*SSH is not enabled.
Jotne
Re: (Urgent) Unable to access mikrotik
Tue Jan 24, 2023 10:13 pm
You should learn about SAFE MODE.
https://wiki.mikrotik.com/wiki/Manual:Console#Safe_Mode
If rommon/mac telnet er not enabled, then reset router, restore backup.
Use Splunk> to log/monitor your MikroTik Router(s). See link below. :mrgreen:
MikroTik->Splunk
anav
Tue Jan 24, 2023 11:15 pm
Why I created this article.......
viewtopic.php?t=181718
Basically besides use safe mode,
Take one port and remove it from the bridge.
add interface=etherX address=192.168.5.1/24 network=192.168.5.0
Then ensure in the input chain you have rule that you dont touch
add action=accept chain=input in-interface=etherX src-address=192.168.5.55 ( or any single IPV4 address you could stick into a laptop etc.)
Regardless what you do for other input chain rules etc.... that will always be available..........
bpwl
Tue Jan 24, 2023 11:51 pm
Sometimes a console will safe your access;
e.g. use MT Woobm in the USB port if there is a USB connector, like on hAP ac2, hEX, Omnitk, and many others. Didn't try another USB-serial adapter, but should work as well.
Users browsing this forum: Bing [Bot], Gomo, GoogleOther [Bot], kolt, woland and 68 guests
