Josephny
How to monitor for attacks
Wed Jan 25, 2023 1:53 pm
I've been wondering about monitoring for incoming attacked (DDOS, port scanning, etc.).
Does RouterOS have capabilities to alert an admin when under attack?
Thanks!
anav
Re: How to monitor for attacks
Wed Jan 25, 2023 2:11 pm
How many attacks have you had in your lifetime?
holvoetn
Wed Jan 25, 2023 2:17 pm
How would he know if he doesn't know how to monitor it ? :lol:
Chicken and egg ...
Josephny
Wed Jan 25, 2023 2:22 pm
I see various firewall-based solutions that drop packets from sources that have more than 32 tcp connection states of type "new"
I don't see a way to block UDP attacks.
I don't believe I am or have been under attack.
I'm just curious if monitoring for attacks is something you professionals recommend.
erlinden
Wed Jan 25, 2023 2:29 pm
You might want to have a look at these YouTube videos:
Bruteforce protection - MikroTik firewall rules:
https://youtu.be/UXGVQmFUfL4
Port knocking with MikroTik:
https://youtu.be/ZaWTuqIdhLM
anav
Wed Jan 25, 2023 2:58 pm
I am a minimalist. If it has nothing to do with traffic that should flow I tend to shy away from it.
However there are a few things one can do, not that much.........
Josephny
Wed Jan 25, 2023 3:37 pm
I only recently learned of about port knocking and it is really cool!
And that is a great video (part of a great video series).
The brute force protection suggested in the other video is cool also.
Thanks!
anav
Wed Jan 25, 2023 3:58 pm
The port knocking is useful in terms of getting a better understanding of how the router config works and what can be done.
I use wireguard for remotely connecting to the router.
Josephny
Wed Jan 25, 2023 4:04 pm
As do I, thanks in great part to your help.
And WG has been working very well across 4 MT routers and 2 Ubiquiti UDM's.
I did notice, however, that if I keep Winbox open just sitting there every now and then it will disconnect and reconnect. I wonder if the IP connectivity between sites drops for a moment and that's what's causing it, or something else.
holvoetn
Wed Jan 25, 2023 4:06 pm
Exactly that. Wireguard will recover (and usually Winbox too).
When running something like Azure Virtual Desktop over Wireguard, I also see it happening on unstable connections. AVD is VERY picky towards connection stability.
mozerd
Forum Veteran
Forum Veteran
Wed Jan 25, 2023 4:18 pm
Perhaps you should consider MOAB blocks over 600 million Bad Guys from attacking your Internet » Here's how «
Users browsing this forum: alexmason, Bing [Bot], gdanov, InfraErik, Mr47 and 133 guests
