ZMLM79
Wireless Wire Cube adpair / aypair random reset
Thu Jan 26, 2023 3:50 pm
Afternoon. I have experienced in some of our customers that one of the Cubes randomly loses all configuration. Like a hard reset was made. It's not easy to fully reset a cube, as we all know. Is there any reason why we are getting cubes losing all configuration to the point that we need to configure them again? Thank you
It's more frequent with the Slave. The Cube does not show on Winbox unless I plug it to the same switch or machine. Then it will show with 0.0.0.0 as IP, which means that it was reset.
normis
Re: Wireless Wire Cube adpair / aypair random reset
Thu Jan 26, 2023 4:19 pm
The unit could be having hardware issues, I suggest to send it for Warranty repair for inspection
ZMLM79
Thu Jan 26, 2023 5:01 pm
Thanks for your answer. We had at least 10 cases. Is there a chance that these 10 devices might have hardware issues? Would a firmware upgrade fix this? Thanks
normis
I suggest to take one of them and give it to the seller for analysis
ZMLM79
Thu Jan 26, 2023 5:35 pm
Thanks again. So just to be sure. You never heard about this issue before?
Users browsing this forum: ajayrooplall, FranMercedesG, Google [Bot], smirgo and 49 guests
