jeevess
MikroTik Cube 60Pro mythically thin Ethernet cable
Thu Jan 26, 2023 5:49 pm
Currently trying to install & configure the lovely MikroTik Cube 60Pro pair that I just received.
If you look at the Mikrotik product page and for that manner ANY and all suppliers
they have this wonderfully small thin ethernet cable entering the back of the Cube.
This is not included in the box, only an Ethernet POE injector.
All my Ethernet cables are thick and fat.
From where do I buy this miraculous thin cable, for me I'd also like it to be about 5 metres long!
Do tell me
sirbryan
Re: MikroTik Cube 60Pro mythically thin Ethernet cable
Thu Jan 26, 2023 6:06 pm
That's a 3D rendering of a cable.
I use Ubiquiti's UISP Cable Pro for most of my installs, and it fits through the grommet just fine (you take it off, find the split, wrap the grommet around the cable, and sandwich it between the two caps).
Users browsing this forum: No registered users and 15 guests
