joshhboss
Newbie-- Recursive Routes-- Mangle -- Fasttrack?
Fri Jan 27, 2023 4:38 am
So im new to mikrotik.. but ive been kind of obsessing and spending all my free time trying to understand and improve.. what I was trying to practice here on a small hex.. because im providing internet to just one office for an event so I figured this would be a good exercise.. Should only have about 20 or so devices.. maybe 40 and I doubt it,. im including watches and phones.. Now I wanted to try doing recursive routes and with failover - (Internet connections will be a starlink and a mikrotik lte dish. LTE really only ever gets like 40 megs) but I was going to have the LTE as a failover.. Now in the exercise in the office it seem to work pretty good but im wondering if the Fasttrack being enabled will be a problem.. (Ive starred at that packet flow diagram and im still pretty much learning as Im practicing... sorry I just learn that way.. ) I had a mangle rule there to just try it and it seems to work as well but I dont know if I should continue to use it if I have fast track enabled. Im posting below just to see if anyone can point out if im doing this right or really wrong..
[admin@HEX-Event] > export
# jan/26/2023 21:30:52 by RouterOS 7.7
# software id = E15E-ZB1M
# model = RB760iGS
# serial number =
add admin-mac==auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1_Wan1
set [ find default-name=ether2 ] name=ether2_Wan2
/interface wireguard
/interface vlan
add interface=bridge name=30Production vlan-id=30
add interface=bridge name=200Management vlan-id=200
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=TrustedLAN
/interface lte apn
add interface=ether1_Wan1 name=server1
/ip hotspot profile
add name=30Production ranges=10.30.0.10-10.30.3.250
add name=bridge ranges=192.168.81.10-192.168.81.250
add address-pool=30Production interface=30Production lease-time=8h name=30Production
add address-pool=bridge interface=bridge lease-time=8h name=Bridge81
/port
set 0 name=serial0
/routing table
add disabled=no fib name=WAN21
/snmp community
add addresses=::/0
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=sfp1
set generic-timeout=5m tcp-established-timeout=8h udp-stream-timeout=1m
set discover-interface-list=all
/ipv6 settings
add comment=defconf interface=ether1_Wan1 list=WAN
add interface=wireguard1 list=TrustedLAN
add interface=bridge list=TrustedLAN
add interface=miamievent list=TrustedLAN
/interface ovpn-server server
set auth=sha1,md5
/interface wireguard peers
add address=192.168.81.1/24 comment=defconf interface=bridge network=192.168.81.0
add address=10.30.0.1/22 interface=30Production network=10.30.0.0
add address=192.168.200.5/24 interface=200Management network=192.168.200.0
/ip dhcp-client
add add-default-route=no comment=defconf interface=ether1_Wan1
add add-default-route=no interface=ether2_Wan2
add address=10.30.0.0/22 dns-server=8.8.8.8,1.1.1.1 gateway=10.30.0.1
add address=192.168.81.0/24 dns-server=192.168.81.1,8.8.8.8 gateway=192.168.81.1
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1
/ip dns static
/ip firewall address-list
add address=192.168.0.0/16 list=PrivateIPs
add address=172.16.0.0/12 list=PrivateIPs
add address=10.0.0.0/8 list=PrivateIPs
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" in-interface-list=!TrustedLAN
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-routing chain=prerouting disabled=yes dst-address-list=!PrivateIPs new-routing-mark=WAN21 passthrough=yes src-address=192.168.81.249
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether1_Wan1
add action=masquerade chain=srcnat comment="defconf: masquerade" ipsec-policy=out,none out-interface=ether2_Wan2
add disabled=no dst-address=4.2.2.2/32 gateway=10.10.10.1 routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=4.2.2.2 pref-src="" routing-table=main scope=11 suppress-hw-offload=no target-scope=11
add disabled=no dst-address=9.9.9.9/32 gateway=192.168.31.1 routing-table=main scope=10 suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=9.9.9.9 pref-src="" routing-table=main scope=11 suppress-hw-offload=no target-scope=11
/snmp
/system clock
set time-zone-name=America/New_York
/system identity
set name=HEX-Event
/system ntp client
set enabled=yes
/system ntp client servers
add address=time.windows.com
/system scheduler
/tool mac-server mac-winbox
/tool romon
set enabled=yes
[admin@HEX-Event] >
chechito
Re: Newbie-- Recursive Routes-- Mangle -- Fasttrack?
Fri Jan 27, 2023 6:07 am
Newbie-- Recursive Routes-- Mangle -- Fasttrack? = Problems
joshhboss
Fri Jan 27, 2023 6:49 am
So give up and not try? Don’t post and just pay someone else to do it ? Always amazes me the guys who never needed to learn and just spawned onto the earth and knew everything.. if only there were a place you could find a community of people who enjoy learning and helping others learn…
Jeez..
Sorry I asked? 😕
joshhboss
Fri Jan 27, 2023 7:02 am
And I’ve read how fast track causes problems with mangle just during the labs it looked like it was working,, didn’t know if the post I was reading was older or maybe something in ROS. Which made it possible even tho I didn’t see it in the change log.. ANYWAYS!! Since I wasn’t sure and don’t trust ChatGPT I figured I’d try here..
joshhboss
Fri Jan 27, 2023 2:24 pm
Disabled Mange btw! Cause im keeping fasttrack and it's a small network, just wanted some sort of fail over.
anav
Fri Jan 27, 2023 2:25 pm
Come up with a more concrete plan, what will the network consist of, what vlans will you have, provide the with network diagrams and set of well though out user requirements. The requirement should drive the config, as opposed to hey I want to try this or that....... As far as starlink is concerned be aware you are really getting a private WANIP from that service.....
Attempt a config, then come here asking for help if it doesnt work out.......... and you will get far more traction!!
Another avenue of self help is take a laptop and load EVE-NG and you can create your own networks using CHR etc..... Its really cool.
Users browsing this forum: billyerasmus101, Google [Bot], Majestic-12 [Bot], nl2024, r0nzzibb and 217 guests
