mestresandro
RB760igs I can't ping workstations or access shared folders
Fri Jan 27, 2023 1:01 pm
I have an RB760iGS
configured with ppoe client internet - Internal dhcpserver 172.16.0.0/24 nat active
all internet browsing works perfectly
But I can't access any network maq or a printer on the network I try to ping and it doesn't find the network maq.
You know what could be going on.
if anyone can help me?
anav
Re: RB760igs I can't ping workstations or access shared folders
Fri Jan 27, 2023 2:09 pm
without an export of your config, No!
mestresandro
Tue Jan 31, 2023 9:48 pm
Friend follows RB 760 script
can you help? from the rb pingo desktop - but I can't access the shared folder on the desktop, nor install a network printer
anav
Tue Jan 31, 2023 11:24 pm
(1) This is a setting I rarely if ever see, suggest unless there is a reason to remove it.............
set tcp-established-timeout=30m
(2) HERE IS THE MAIN PROBLEM
add address=172.16.0.1/24 interface=ether5-Rede_local network=172.16.0.0
TO:
add address=172.16.0.1/24 interface=REDE_LOCAL_PONTE network=172.16.0.0
(3) The IP DHCP CLIENT should be DISABLED, your WAN is through the pppoe interface!!!!
/ip dhcp-client
add disabled=no interface=ether1-Redel
(4) Assuming 8291 is your winbox port, REMOVE IMMEDIATELY THIS IS A SECURITY RISK!!!!
add action=accept chain=input dst-port=8291 in-interface-list=OPERADORAS \
protocol=tcp
You should never access the winbox port directly from external www. Change to something like
add action=accept chain=input dst-port=8291 in-interface=REDE_LOCAL_PONTE
protocol=tcp
If you want to remotely configure the mikrotik, then use wireguard to tunnel into the router and then access winbox.
mestresandro
Mon Feb 06, 2023 1:26 pm
Thanks, I made the changes and even so something blocks the ping between the machines, I'm suspicious of the ppoe connection - but I've looked at the route and it doesn't seem to influence anything.
I even changed the internal ips to 192.168.0.0/24 to see and nothing
I did a test by putting a wifi router in bridge mode connected to the mikrotik and the maq behind this router are normally - without it it is not.
could it be anything else?
mestresandro
Mon Feb 13, 2023 7:22 pm
I noticed that if I connect vpn everything will work maybe it could be something in ppp or route - follow ppp file
anav
Mon Feb 13, 2023 7:24 pm
Would need to see the latest full config..........
kevinds
Long time Member
Long time Member
Tue Feb 14, 2023 4:29 am
Also remember that the Windows Firewall blocks all that stuff by default.. Check that your hosts do not have this network set as "Public".
Users browsing this forum: qatar2022 and 56 guests
