baz
Many VLANs + DHCP Servers + hw offload ?
Fri Jan 27, 2023 1:14 pm
I need to configure a CRS109-8G-1S (RouterOS 7.7) to have:
- some port assigned to an untagged VLAN ("access port")
- some port assigned to tagged + untagged VLANs ("trunk" port)
- the routerOS may work as router and firewall between this VLANs
- the traffic intra-vlan may be offloaded
- the RouterOS may offer DHCP server to each VLAN
Is this possible? I tried with many different bridges (one for every VLAN) to bind many DHCP servers to different VLAN, but the ethernet traffic seems not isolated (every port can reach every other port, via cpu1 interface I think).
I tried using a single bridge, as suggested here https://help.mikrotik.com/docs/pages/vi ... bridPorts) but the problem is to assign different DHCP servers to different VLANs ( I cannot find a way to bind DHCP Server to VLANs in this scenario).
What is the right way to have this? Basically I need only functions of a L3 switch: tagged/untagged vlan on ports, routing, basic firewall filtering.
thanks
anav
Re: Many VLANs + DHCP Servers + hw offload ?
Fri Jan 27, 2023 2:08 pm
It will work, one bridge, but without seeing your attempt/config, cannot help much
tdw
Fri Jan 27, 2023 3:37 pm
Later on that page has an example with inter-VLAN routing https://help.mikrotik.com/docs/pages/vi ... LANRouting - you attach DHCP servers to the /interface vlan interfaces.
ConradPino
Fri Jan 27, 2023 8:44 pm
My posts on this topic apply: Help with VLANs on Bridge viewtopic.php?t=192869
BartoszP
Fri Jan 27, 2023 10:18 pm
Users browsing this forum: Ahrefs [Bot], Rendy and 55 guests
