karaYusuf
Pinging google with different interfaces
Fri Jan 27, 2023 3:38 pm
Hello guys,
I wanted to ping google via three interfaces to check the internet connection with this command line:
:ping 8.8.8.8 src-address=ether1IpAddress count=1
:ping 8.8.8.8 src-address=lte1IpAddress count=1
[:ping 8.8.8.8 src-address=wlan1IpAddress count=1
My problem is that it does not work anymore if the interface with the smallest default-route-distance has the ping-status on "timeout". With this my conclusion is that every ping to google takes the route over the interface with the smallest default-route-distance. I wanted to know what I have to configure to ping google with the interfaces even if other interfaces are not working anymore.
Every interface here is listed in WAN.
Any help would be appreciated:)
diamuxin
Re: Pinging google with different interfaces
Fri Jan 27, 2023 8:12 pm
What you need is called recursive routing, which allows multiple routes to ping check even if the route distance is 2, 3, etc.
Here is some information:
https://help.mikrotik.com/docs/pages/vi ... d=26476608
BR.
BartoszP
Fri Jan 27, 2023 8:14 pm
Users browsing this forum: Johann1525, zhouck and 33 guests
