Did you find this image useful?
Yes
3 (43%)
No
4 (57%)
Total votes: 7
cdhtlr
Ookla Speedtest Container
Fri Jan 27, 2023 11:01 pm
Before MikroTik released version 7, it was difficult to do a speedtest from the router to Ookla servers, whereas in Indonesia no one provided a Btest server for free.
Now MikroTik supports container installation. So I modified a Golang-based speedtest app on GitHub and made it a Docker image.
With this image, we can speedtest various servers provided free of charge by Ookla, Netflix, etc., just like when we speedtest using a PC.
I did a speedtest based failover using this image and made a demo in https://youtube.com/playlist?list=PLyx1 ... 3HwaJSULEn
These application and image are easy to monitor from a web browser and compatible with Netwatch http-get mode. If you are interested, you can download it at https://hub.docker.com/r/cdhtlr/mikrotik-speedtest
Hope you will like it.
Alevx94
Re: Ookla Speedtest Container
Thu Aug 03, 2023 10:20 am
first of all thanks for supplying this image.
I managed to pull the docker and I successfully run it, but a couple things are not clear to me :
  • How should I start the speedtest?
  • How can I configure a different server for the test? (maybe how to retrieve the url from ookla or similar)
Thanks for your work!
cdhtlr
Fri Aug 04, 2023 1:30 am
Thank you too for using this image.
I'm glad to hear you have successfully run it. Let me make it clear.
You can start speedtest by:
  • Access the main page of this container at http://192.168.1.2:8080 (depending on the IP and port you give to this container). You will automatically do a speedtest to the server that you have set. Then you can check the results on the chart page (http://192.168.1.2:8080/chart ).
    If you wish, you can also access http://192.168.1.2:8080/condition to see the speedtest comparison results based on the MIN_THRESHOLD variable, the default is 1Mbps. The speedtest results will tell whether your download speed is below or above MIN_THRESHOLD.
  • Using the fetch facility in MikroTik RouterOS to call the speedtest program like:
    :local result [tool fetch mode=http url="http://192.168.1.2:8080" output=user as-value]
    :local result [:put ($result->"data")]
    :log info "Your actual download bandwidth is $result Mbps"
    You are free to do any scripting based on the results of the speedtest performed by the router, such as failover and so on. You are free to do scripting with your creativity.
You are free to use any server as a speedtest server. It doesn't actually have to be an ookla server.
For example you can use this ubuntu download url as the URL to download:
https://releases.ubuntu.com/22.04.2/ubu ... -amd64.iso
But if you want the best Ookla server from your internet then you can look for it at:
https://c.speedtest.net/speedtest-servers-static.php
You will find many "server url". Use one of them in this container configuration.
Thank you.
cdhtlr
Fri Aug 04, 2023 1:34 am
I want to know, what MikroTik router device are you using and what version of RouterOS is it?
gmanfredax
Sat Aug 12, 2023 10:21 am
Hi, I followed the guide on docker to configure a container on mikrotik but every time I open the speedtest link I always get 0.0
I also tried changing the URL env but the result doesn't change
This is my router configuration:
# 2023-08-12 08:37:45 by RouterOS 7.10.2
# model = RB5009UG+S+
add admin-mac= auto-mac=no comment=defconf igmp-snooping=yes multicast-querier=yes name=bridge vlan-filtering=yes
add name=bridge-docker
/interface veth
add address=192.168.1.2/24 gateway=192.168.1.1 name=veth1-speedtest
/interface vlan
add interface=bridge name=vlan100-iot vlan-id=100
add interface=bridge name=vlan110-vs vlan-id=110
add interface=bridge name=vlan120-hdmi-extender vlan-id=120
add comment="VLAN FTTH" interface=ether1 name=vlan835_ftth vlan-id=835
/interface pppoe-client
add add-default-route=yes comment=FTTH-OUT disabled=no interface=vlan835_ftth name=pppoe-out1 user=
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp_pool0 ranges=192.168.10.10-192.168.10.100
add name=dhcp_pool50 ranges=192.168.100.10-192.168.100.100
add name=dhcp_pool60 ranges=192.168.110.10-192.168.110.100
add name=dhcp_pool70 ranges=192.168.120.10-192.168.120.100
add address-pool=dhcp_pool0 interface=bridge lease-time=10m name=dhcp1
add address-pool=dhcp_pool100 interface=vlan100-iot lease-time=10m name=dhcp100
add address-pool=dhcp_pool110 interface=vlan110-vs lease-time=10m name=dhcp110
add address-pool=dhcp_pool120 interface=vlan120-hdmi-extender lease-time=10m name=dhcp120
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" name=zt1 port=9993
/zerotier interface
add allow-default=no allow-global=no allow-managed=no disabled=no instance=zt1 name=zerotier1 network=
/container
add envlist=speedtest hostname=speedtest interface=veth1-speedtest logging=yes root-dir=disk1/speedtest workdir=/
/container config
set registry-url=https://registry-1.docker.io tmpdir=disk1/pull
/container envs
add key=URL name=speedtest value="https://jakarta.speedtest.telkom.net.id:8080/download?size=25000000"
add key=MAX_DLSIZE name=speedtest value=1.0
add key=MIN_THRESHOLD name=speedtest value=1.0
add key=CONCURENT_CONNECTION name=speedtest value=4
add key=ALLOW_MEMORY_BUFFER name=speedtest value=YES
add bridge=bridge comment=defconf interface=ether5 pvid=100
add bridge=bridge comment=defconf interface=ether6 pvid=110
add bridge=bridge comment=defconf interface=ether7 pvid=120
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge-docker interface=veth1-speedtest
/interface bridge vlan
add bridge=bridge tagged=bridge,sfp-sfpplus1 vlan-ids=100
add bridge=bridge tagged=bridge,sfp-sfpplus1 vlan-ids=110
add bridge=bridge tagged=bridge,ether8,sfp-sfpplus1 untagged=ether7 vlan-ids=120
add bridge=bridge comment=ont untagged=bridge,sfp-sfpplus1,ether8,ether4 vlan-ids=835
add comment=defconf interface=pppoe-out1 list=WAN
add interface=vlan100-iot list=LAN
add interface=vlan110-vs list=LAN
add interface=vlan120-hdmi-extender list=LAN
add address=192.168.10.254/24 comment=defconf interface=bridge network=192.168.10.0
add address=192.168.100.254/24 interface=vlan100-iot network=192.168.100.0
add address=192.168.110.254/24 interface=vlan110-vs network=192.168.110.0
add address=192.168.120.254/24 interface=vlan120-hdmi-extender network=192.168.120.0
add address= interface=zerotier1 network=
add address=192.168.1.1/24 interface=bridge-docker network=192.168.1.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=1m
/ip dhcp-client
add comment=defconf disabled=yes interface=vlan835_ftth use-peer-dns=no
add address=192.168.10.0/24 comment=defconf dns-server=8.8.8.8,8.8.4.4,192.168.10.254 gateway=192.168.10.254
add address=192.168.100.0/24 dns-server=8.8.8.8,8.8.4.4,192.168.100.254 gateway=192.168.100.254
add address=192.168.110.0/24 dns-server=8.8.8.8,8.8.4.4,192.168.110.254 gateway=192.168.110.254
add address=192.168.120.0/24 dns-server=8.8.8.8,8.8.4.4,192.168.120.254 gateway=192.168.120.254
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.10.254 comment=defconf name=router.lan
/ip firewall address-list
add address= list=WAN
add address=192.168.10.0/24 comment="Home Lan" list=LANs
add address=192.168.100.0/24 comment="IoT Lan" list=LANs
add address=192.168.110.0/24 comment="VS Lan" list=LANs
add action=accept chain=forward in-interface=zerotier1
add action=accept chain=input in-interface=zerotier1
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" connection-state=established,related hw-offload=yes
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
/ip firewall mangle
add action=mark-connection chain=prerouting comment="Mark connections for hairpin NAT" dst-address-list=WAN new-connection-mark="Hairpin NAT" passthrough=yes src-address-list=LANs
add action=masquerade chain=srcnat comment="Hairpin NAT" connection-mark="Hairpin NAT"
add action=masquerade chain=srcnat src-address=192.168.1.0/24
add action=dst-nat chain=dstnat dst-port=8080 protocol=tcp to-addresses=192.168.1.2 to-ports=80
add disabled=no dst-address=0.0.0.0/0 gateway=192.168.1.1 routing-table=main suppress-hw-offload=no
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=MikroTik_RB5009
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
/tool netwatch
add disabled=yes down-script="" host=192.168.1.2 http-codes=200 port=8080 test-script="" type=http-get up-script=""
mftitalia
Fri Nov 10, 2023 12:28 am
Hello, is it possibile to run this on a Hap_AC 2 ?
holvoetn
Fri Nov 10, 2023 7:02 am
Might be a problem.
Hap AC2 architecture is arm and has USB port for external storage, so far so good.
But ... it only has 16Mb of internal storage (where the extraction etc will be done), only 128Mb RAM (some rare units have 256) which is also used for RAM allocation for your container, ....
I guess there you might hit a wall.
mftitalia
Fri Nov 10, 2023 10:10 am
Thanks for info =)
holvoetn
Fri Nov 10, 2023 10:19 am
User tangent made an iperf container which is less then 1Mb.
Might be worthwhile to investigate ?
viewtopic.php?t=195062
Users browsing this forum: No registered users and 4 guests
