brainkiller
CRS125 forwarding LLDP/CDP/MNDP broadcasts
Fri Jan 27, 2023 11:50 pm
I have 2 CRS125 devices in separate locations connected to various other mikrotik devices.
When I enabled neighbor discovery recently to automate building a network topology map I noticed that the CRS125 are forwarding LLDP packets to the other devices.
I cannot seem to figure out how to disable or block this while having hardware offload enabled.
Example topology:
<PC1 sending LLDP> ---- <CRS125> ---- <Omnitik 5>
On the Omnitik I see the LLDP message of PC1.
With hardware offload disabled I can easily block the CDP and MNPD broadcasts using bridge filters and LLDP isn´t forwarded as designed.
I read something about using switch ACLs but this doesn´t seem to be supported on my switch cpus (QCA 8513L)
The wiki suggest to use port isolation for this but I can´t seem to figure it out.
Do any of you have any experience with this kind of issue ?
Thanks for you help.
jbl42
Re: CRS125 forwarding LLDP/CDP/MNDP broadcasts
Sat Jan 28, 2023 10:43 pm
According to
https://help.mikrotik.com/docs/pages/vi ... =103841835
CRS125 should have switch ACLs available in
/interface ethernet switch acl
At the other hand, LLDP should not be forwarded by IEEE802.1D compliant bridges.
In my experience, MT l2hw bridges forward everything with protocol setting to none. Enabling RSTP or STP changes this to IEEE802.1D compliant forwarding and LLDP and similar packets are dropped without requiring specific ACLs.
brainkiller
Sat Jan 28, 2023 11:08 pm
Indeed I also saw this on the help/wiki but when I try this I get:
/interface/ethernet/switch/acl> add action=drop mac-protocol=lldp
failure: policy rules are not supported on this switch chip
I just double checked but all bridges have RSTP configuration on both devices.
Users browsing this forum: pfturner and 49 guests
