capobianco79
ring topology with INTERVLAN ROUTING
Sat Jan 28, 2023 1:04 am
HI i'm using mikrotik swith at work, and i've also made a lab in GNS with 3 route board.
i've tried to make a simple network with 3 switches connected eath other, like SWITCH A , B and C in a ring.
i've tried using one switch , switch A as my router with 3 SVI interfaces under one bridge.
i've create 3 vlan, vlan 10 , 20 and 99 for management.
sw A (vlan 10,30,99 SVI) 10.10.10.254 /24
10.10.30.254 /24
10.10.99.254 /24
sw B ( 10.10.99.12/24 ) sw C ( 10.10.99.12 /24)
the tree switches are connected in a ring topology. i've done the vlan table and make access and trunk ports. if i try to ping with switch its ok i can reach all gateway if i ping from a host connected to the switch nothing happen. sw2 and sw3 has the default gateway
can i have the same scenario like ROUTER ON A STICK if i use three switches in a ring topology ?
thanks
Users browsing this forum: almdandi, ariux, edupre, maigonis and 114 guests
