davidon
WAN Failover using src-nat - How to dynamic IP?
Sat Jan 28, 2023 1:16 am
There is a short tutorial which explains how to setup a failover:
https://wiki.mikrotik.com/wiki/Manual:F ... ll_marking
The tutorial has a step which defines the NAT configs, as follows:
add action=src-nat chain=srcnat out-interface=ether1 to-address=10.1.101.18/24
add action=src-nat chain=srcnat out-interface=ether2 to-address=10.1.200.18/24
These NAT configs use hardcoded IP addresses in the "to-address" field.
But often WAN addresses are dynamic (they may be changed arbitrarily).
So how do I modify the command in the tutorial to be compatible with dynamic IP addresses?
bpwl
Re: WAN Failover using src-nat - How to dynamic IP?
Sat Jan 28, 2023 1:32 am
Use action "masquerade" instead of "src-nat". Masquerade will use the dynamic/changing IP address of the interface as SRC for NAT.
https://wiki.mikrotik.com/wiki/Manual:I ... Masquerade
davidon
Sat Jan 28, 2023 2:33 am
The tutorial is intentionally using "src-nat" instead of "Masquerade" to avoid its disadvantages:
Instead of masquerade, we will use src-nat for our local networks, because we do not want to purge connections which is one of masquarades main features when a primary link fails. We will restrict them with a firewall rules (later in this example)
If I change the value of the "action" field as you wrote, then:
1. I assume that all of Masquerade disadvantages would be applied to my setup.
2. Would I still need to follow the tutorial with the rest of the commands?
I'd rather to avoid Masquerade, if there is some other technique possible in this case.
bpwl
Sat Jan 28, 2023 2:08 pm
Users browsing this forum: Carlcox89, fengyuclub and 48 guests
