moeinfrozen
Set Mikrotik For Esxi vms firewalls
Sat Jan 28, 2023 8:39 am
Hello, I want to put 1 Mikrotik server in Esxi for the firewall of other servers
How can I do this?
All passing traffic must be done from the same Mikrotik server.
joegoldman
Forum Veteran
Forum Veteran
Re: Set Mikrotik For Esxi vms firewalls
Sat Jan 28, 2023 8:58 am
You could do a physical device physically in front of the VMWare Server
You could have a RouterOS VM, and set the VM's to a private network that gateways through the RouterOS VM which has an interface both in the private network and a public network.
Configuration beyond that would be best asked on a ESXi community forum.
pe1chl
Sat Jan 28, 2023 12:10 pm
You make a virtual switch to which your local VMs are connected, and the MikroTik CHR also has a port there. The CHR also has a connection to another virtual switch that is connected to the external network.
You can also do the same using VLANs on a single switch.
BartoszP
Sun Jan 29, 2023 9:22 am
Do not start many topics on the same subject: viewtopic.php?t=193064
Users browsing this forum: MauriceW and 103 guests
