akira463
Script issue, 0 value turns to be false value?
Sat Jan 28, 2023 4:58 pm
Hello again sir, Im having a hard time working on this project. my problem is, even the comment "Counter" is equal to 0 "Zero" the log shows that it has to be paid, and also if you paid not equal to the "Counter" it displays as balance and also needs to be paid, what could be wrong in my code? please do help, thankyou!
:local newMess   "You have received PHP 1600.00 of GCash from JO*MSG: 2021001. Your new balance is PHP 1649.00. Ref. No. 3007882128690."
:local amount [:pick $newMess ([:find $newMess "PHP "] + 4) [:find $newMess ".00 of GCash"]]
:local sender [:pick $newMess ([:find $newMess ". "] + 2) [:find $newMess  " w/"]]
[/ppp secret set "annexOffice" comment=$newComm]
:if ($cost <= 0) do={
	:log warning "We receive your payment amounting of $amount.00 Pesos, your credit is $total.00 Pesos your account will be now re-activated"
	[/sys scr run [find name="annexOffice"]]
} else={
	:log warning "Please settle your balances amounting of $total.00 Pesos"
rextended
Re: Script issue, 0 value turns to be false value?
Sat Jan 28, 2023 5:18 pm
It's time to do some math...
debug code
:local newMess "You have received PHP 1600.00 of GCash from JO**E J* P. 09360442315 w/ MSG: 2021001. Your new balance is PHP 1649.00. Ref. No. 3007882128690."
:local accMsg [:pick $newMess ([:find $newMess "MSG: "] + 5) [:find $newMess ". Your new"]]
:local ref [:pick $newMess ([:find $newMess "Ref. No. "] + 9) ([:len $newMess] - 1)]
:put $newMess
:put $amount
:put $sender
:put $accMsg
:put $ref
:local comm "Acc Number: 2021001 Plan: 35mbps Cost: -1601"
:local accNum [:pick $comm ([:find $comm "Number: "] + 8 ) [:find $comm " Plan:"]]
:local cost [:pick $comm ([:find $comm "Cost: "] + 6) ([:len $comm])]
:local total ([$cost] - [$amount])
:put $comm
:put $accNum
:put $cost
:put $total
:put "\$cost ($cost) - \$amount ($amount) = \$total ($total)"
terminal results code
1600
09360442315
2021001
3007882128690
2021001
-1601
-3201
$cost (-1601) - $amount (1600) = $total (-3201)
Is wanted -3201 ???
Or probably $total must be $cost + $amunt, because cost is already negative?
akira463
Sat Jan 28, 2023 5:21 pm
Thankyou sir , for your quick reply.! im gonna analyze again my code, thankyou,
rextended
Sat Jan 28, 2023 5:24 pm
Probably this two points:
must be
:local total ([$cost] + [$amount])
and
probably must be the ckeck of the total, the balance, not the cost...
:if ($total >= 0) do={
and
become
:log warning "Please settle your balances amounting of $($total * -1).00 Pesos"
akira463
Sat Jan 28, 2023 5:25 pm
My problem is, when "Cost" counter hit zero or negative amount , it logs that i have remaining balance of 0.00 Pesos. i do want to log it as "Payment receive your account is now activated" it balance is = equal to zero or -negative amount
rextended
Sat Jan 28, 2023 5:26 pm
read previous post, and please remove quote on your previous post, and do not quote all block when is useless.
akira463
Sat Jan 28, 2023 5:45 pm
It works now sir!!! Thankyou for your help! I hope someday i can repay you, God Bless you !
Users browsing this forum: No registered users and 44 guests
