bornpilot
RouterOS IP Firewall Filter Rules not working?
Sat Jan 28, 2023 8:57 pm
Greetings, I am running RouterOS 7.7 with a very basic setup. When I setup my firewall rules I have a default deny all on the bottom of the list. When I add an allow for TCP traffic it also allows DNS UPD traffic, I am not sure why and it's hard to know if my filters are applying correctly. The following is my last filter number 8.
 8    ;;; Default: Drop All
      chain=forward action=drop log=yes log-prefix=""
When I allow the following rule, see the number for it's location, then DNS traffic is also allowed. The DNS Traffic is UDP Port 53
3  ;;; Allow HTTP(S) on LAN Net
      chain=forward action=accept connection-state=established,related,new,untracked protocol=tcp port=443,80 log=yes log-prefix=""
Right not for testing these are the only two filters enabled on the firewall.
Why is the DNS trafficking going through on the forward chain?
anav
Re: RouterOS IP Firewall Filter Rules not working?
Sat Jan 28, 2023 9:16 pm
/export file=anynameyouwish ( minus router serial# and public WANIP information )
jvanhambelgium
Forum Veteran
Forum Veteran
Sat Jan 28, 2023 9:28 pm
Are you using the Mikrotik as a DNS-server ?
Then it is normal that FORWARD chain will not deal with any traffic GENERATED by the Mikrotik (example ; upstream DNS queries) or RESPONSES back to the Mikrotik.
bornpilot
Sat Jan 28, 2023 9:34 pm
Attached is the file. I had been testing some flashStart and Lucid View web filter tests. In this you will see that there are a couple of networks. The Mikrotik network in question is Natted behind another firewall and I have yet another network that's bridged to the the LAN on Router1.
bornpilot
Sat Jan 28, 2023 9:38 pm
Good Question. No, the DNS servers from quad9, so the forward chain should work.
bornpilot
Sun Jan 29, 2023 1:57 am
If the default firewall filter rule is allow what is the signficiance of adding the following rule?
;;; accept established,related,untracked
      chain=forward action=accept connection-state=established,related,untracked
bornpilot
Sun Jan 29, 2023 2:06 am
I believe my issue was that I had some established connections that had not cleared. I lowered some of those setting from my test and cleared my connections packet flow seems to be working as expected.
Thanks!
fcollini
Tue Apr 04, 2023 7:08 pm
Dear Bornpilot,
thanks so much for the mention; always at Mikrotik expert's side :)
Users browsing this forum: ChadRT and 123 guests
