pablorib
OSPF DB mismatch on same AREA routers v6.49.7
Sat Jan 28, 2023 10:44 pm
We are facing the following issue between two 1072 running 6.49.7.
In a multiple area OSPF deployment.
Adjacency is fine. Some networks are not being send to routers in one area.
LSAs are present on the ABR (OSPF DB) but not on the other routers in this area.
As a temporary workaround we are turning this area into a STUB area.
ABR
/routing ospf area
add area-id=1.0.0.40 name=area40
/routing ospf interface
add interface=vlan400_R-SERVER network-type=broadcast
/routing ospf instance
set [ find default=yes ] redistribute-other-ospf=as-type-1 redistribute-static=no router-id=10.0.0.3
Router on AREA40
/routing ospf area
add interface=400-wan network-type=broadcast priority=0
set [ find default=yes ] redistribute-other-ospf=as-type-1 redistribute-static=no router-id=10.0.0.8
ABR showing a subnet
Router on AREA 40 not showing
Users browsing this forum: No registered users and 60 guests
