Belyivulk
Connecting two radios to one antenna
Sat Oct 20, 2007 11:44 pm
Hi Guys,
Im looking at ways to build in a backup for our core routers, and the stumbling block i keep hitting is transferring the radio configuration. The problem being a failover router will need to have radios in it, in order to keep links up, but i can only connect one antenna to one radio.
Does anyone know of a viable solution?
tgrand
Long time Member
Long time Member
Re: Connecting two radios to one antenna
Sun Oct 21, 2007 5:09 am
Signal Splitter/Combiner
Belyivulk
Sun Oct 21, 2007 6:46 am
Thanks, can you point me in the direction of a splitter that is for this use? all the combiners / splitters ive found are not suitable for this application
steveloomis
Sun Oct 21, 2007 10:48 pm
In my opinion, use two completely redundant systems, antennas, powersupply etc. Keep it simple and it will work. Backup links I've run were this way, one in standby, the other active. I even manually switched them over to keep it simple. I used a pager for failure notice so I could respond quickly if necessary.
Steve Loomis
Belyivulk
Sun Oct 21, 2007 11:08 pm
Hi Steve,
Thats all well and good, except many of our links are good two hours drive from where we reside, so a manual switch over would be a huge inefficiency. I had hoped two run to seperate everything with the exception of the antenna. This would help us deal with 99% of problems we encounter
jwcn
Mon Oct 22, 2007 1:44 am
How much money will you save not buying another antenna? You'll probably spend more for a splitter/combiner...
ste
Mon Oct 22, 2007 8:13 am
Splitters are bad for your signal
Here was a discussion on dual-polarization
antennas. Try these.
Stefan
promind
Mon Oct 22, 2007 10:43 am
you need this:
1 antenna + dual polarized feedhorn.
3 boards per side
first board simple wds bridge to the other side
second board the same as the first
thirb board uses 2 ethernet ports with bonding over them
you can setup balance-rr for more bandwidth or in your case you need failover link or mode 1/active-backup/.
make sure you put miimon and if one of your board fails the other will take it's place within less than a second.
I've done this using Linux haven't tested it yet with mikrotik but I'm looking forward to replace my current equipment with mikrotiks.
Users browsing this forum: No registered users and 24 guests
