pikpik
High cpu usage on crs309
Mon Jan 30, 2023 2:13 pm
RB: CRS309-1g-8s+
Config: default + a few vlans (30) , one bonding interface, 2x bridge. no filters and no fw rules.
Traffic : ~1Gbps ~ 80k pps
More info on screens.
https://imgur.com/a/I0jNdNa
Fast forward enabled on bridge, hw offlowading on ports and vlans. What am I doing wrong ?
rextended
Re: High cpu usage on crs309
Mon Jan 30, 2023 2:38 pm
When you need to repair your car, do you take the photos to the mechanic?
From the photos, how can you see how the device is configured?
Apparently everything is wrong, you have made all virtual vlans, instead of letting the bridge manage the vlans.
That's a switch, not a router (and probably is the wrong configuration also if is a router)
pikpik
Mon Jan 30, 2023 2:56 pm
I think you are right.
my cfg:
bridge ports : one sfp+ port + all vlans
vlans: made in inteface/vlan on interface bonding thats all
rextended
Mon Jan 30, 2023 3:21 pm
I can confirm:
[…] everything is wrong, you have made all virtual vlans, instead of letting the bridge manage the vlans […]
pikpik
Mon Jan 30, 2023 3:26 pm
I can confirm:
what do i need to change for the vlans to work in hardware?
rextended
Mon Jan 30, 2023 3:37 pm
search the two guide on forum, and read mikrotik help
pikpik
Mon Jan 30, 2023 4:12 pm
i can't find for my case.
mkx
Mon Jan 30, 2023 4:27 pm
How about this one: viewtopic.php?t=143620
Indeed it's not cookbok recipe for your particular case, you should combine a few things (but then you have to understand a few basics about how ROS works).
pikpik
Sorry. This is my diagram
erlinden
Mon Jan 30, 2023 4:52 pm
pikpik
Mon Jan 30, 2023 8:41 pm
AidanAus
Thu Feb 02, 2023 7:47 am
they are showing you what is supported via the hardward offloading feauture, scroll down for vlan configuration examples https://help.mikrotik.com/docs/display/ ... tures-VLAN
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 144 guests
