Musti
No router menagement possible while connected via VPN
Mon Jan 30, 2023 4:29 pm
I cannot access any RouteBoard management (ssh/web/winbox), when I am remotely connected using L2TP/IPSec VPN.
I can access any other hosts on the remote LAN except the router. I can ping the router.
MikroTik model is RB2011UiAS, RouterOS version is 6.48.6.
What could be the problem?
REGARDS
Musti
Musti
Re: No router menagement possible while connected via VPN
Thu Feb 02, 2023 4:43 pm
WAN/ether1 is linked to ISP using PPPoE.
Here is config:
# jan/27/2023 19:20:50 by RouterOS 6.48.6
# software id = B06R-8NB4
# model = RB2011UiAS
# serial number = ***********
add admin-mac=18:FD:74:D2:EF:D3 arp=proxy-arp auto-mac=no comment=defconf \
name=bridge
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out1 \
password=********** use-peer-dns=yes user=*******@**********
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=dhcp ranges=192.168.1.100-192.168.1.254
add name=vpn_pool ranges=192.168.1.97-192.168.1.99
add address-pool=dhcp disabled=no interface=bridge name=defconf
/ppp profile
set *0 local-address=192.168.1.1 remote-address=vpn_pool
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp1
/interface l2tp-server server
set authentication=mschap2 enabled=yes ipsec-secret=******* use-ipsec=required
add address=192.168.1.1/24 comment=defconf interface=bridge network=\
192.168.1.0
/ip dhcp-client
add address=192.168.1.0/24 comment=defconf dns-server=1.1.1.1,8.8.4.4 \
gateway=192.168.1.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,8.8.4.4
/ip dns static
add address=192.168.1.1 comment=defconf name=router.lan
established,related,untracked
invalid
add action=accept chain=input dst-port=500,4500,1701 protocol=udp
add action=accept chain=input protocol=ipsec-esp
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add disabled=yes distance=1 gateway=192.168.8.1
/ppp secret
add name=********* password=************
add local-address=192.168.1.1 name=************* password=************* \
remote-address=192.168.1.99
remote-address=192.168.1.98
/system clock
set time-zone-name=Europe/Warsaw
/system identity
set name=RouterOS
/tool mac-server
/tool mac-server mac-winbox
erlinden
Thu Feb 02, 2023 4:48 pm
The firewall is probably blocking because the VPN clients are not on the LAN address list:
anav
Thu Feb 02, 2023 6:10 pm
(1) Concur somewhat with erlinden.......... I believe you need specific firewall rules for the subnet or IP address you have designated/assigned for ispec as to my limited knowledge (peer address??), an ipsec interface cannot be added to an INTERFACE LIST. So it doesnt matter about LAN INTERFACE list.
suggesting in this order............
add chain=input action=accept src-address=IPSEC SUBNET OR IPSEC IP-ADDRESS
(2) Not required should be disabled or removed as IP dhcp client settings are handled through pppoe.
/ip dhcp-client
(3) default static dns rule should be removed.
/ip dns static
(4) Should be sent to NONE as mac-server by itself is not a secure access method
/tool mac-server
Musti
Fri Feb 03, 2023 3:05 pm
Thank you guys,
remote ip adressess are from LAN IP address space (192.168.1.97-99), so the rule:
shoudn't be blocking vpn tunnel traffic. I am able to get to other LAN addresses via vpn, except the 192.168.1.1.
WAN IP address is getting by PPPoE, are you sure I should disable dhcp-client on ether1 interface?
/ip dhcp-client add comment=defconf interface=ether1
REGARDS
Musti
anav
Fri Feb 03, 2023 3:32 pm
I am not an ipsec expert but I think its a mistake to use your LANIPs for your ipsec, use something else anything
10.10.10.X for example use the firewall rule I provided and it should work.
No the pppoe is doing the client work you dont need IP dhcp client settings.
Musti
Fri Feb 03, 2023 4:34 pm
OK, I added new user:
add local-address=172.16.10.1 name=****************** password=************ remote-address=172.16.10.99
and inserted new firewall rule:
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=input src-address=172.168.0.0/24
as you suggested.
However, I still cannot access router IP; all other LAN hosts and Internet are available.
REGARDS
Robert
anav
Re: No router menagement possible while connected via VPN  [SOLVED]
Fri Feb 03, 2023 11:17 pm
Check it out.......
and inserted a new firewall rule.......
Try with
add action=accept chain=input src-address=172.168.10.0/24
Musti
Tue Feb 07, 2023 10:59 am
Oh... of course! :) My bad.
I had to reconfigure the router from the scratch due to some problem with PPPoE address assigning.
I have used following config:
/ppp secret
add local-address=10.10.10.1 name=******* password=*********** remote-address=10.10.10.11 service=l2tp
add action=accept chain=input dst-port=500,1701,4500 protocol=udp
add action=accept chain=input src-address=10.10.10.0/24
and now I am able to access router management.
Thank you anav for your help!
Users browsing this forum: No registered users and 100 guests
