berzerker
New Ubiquiti Multi-gig RJ45 NBASE-T Transceiver not working
Mon Jan 30, 2023 6:47 pm
Hello, I have a few of these UACC-CM-RJ45-MG new "multi-gig" NBASE-T RJ45 transceivers and they do not appear to be working in any of my SFP+-supported Mikrotik gear.
I get no link activity with both autonegotiation and manual speed negotiation. This device seems similar to the S+RJ10, just using a newer revision BCM chip internally.
Any plans to support it?
anav
Re: New Ubiquiti Multi-gig RJ45 NBASE-T Transceiver not working
Mon Jan 30, 2023 6:52 pm
I doubt its a priority unless they have customer, (talking in the $100,000+ range) that requests that functionality.............
berzerker
Mon Jan 30, 2023 6:53 pm
If that were the stipulation, IPv6 would have been supported in RouterOS 5 lol.
This doesn't seem like a huge deal to implement. Like I mentioned, it's based on a newer revision of similar hardware in the S+RJ10. If they're working on an /r3 of it they may be working on it already, just would be nice to hear from them directly.
sirbryan
Tue Jan 31, 2023 10:03 am
What version of RouterOS are you running? What version of firmware is on the switch/router? There were some SFP+ updates in 7.4.1 and later I believe.
I have a couple of the EA versions of those and they seem to work fine. The switch (or router, in my case a CCR2004) seems to negotiate 10G to the SFP+, which in turn negotiates 2.5G to the other device (in my most recent test, the latest revision of the Wave AP with a 2.5G copper port).
berzerker
Tue Jan 31, 2023 9:17 pm
I'm on the 7.7 on all devices. CRS309 is firmware 7.6 (which I'm trying). I don't believe they worked in my CCR2004 either. Mine are EA as well. I don't get any links to any devices when they're in, with autonegotiation or manual setting.
sirbryan
Tue Jan 31, 2023 10:17 pm
And under System Routerboard the firmware also 7.7?
7.8b2 has a warning that it's not for CRS300 devices.
berzerker
Tue Jan 31, 2023 10:18 pm
7.6 firmware. I'm not on 7.8b on any device. Didn't think 7.6 firmware mattered since you mentioned the fixes were 7.4.1
sirbryan
Tue Jan 31, 2023 10:50 pm
Oh, I was reading on my phone on a rooftop, and I thought I saw 7.8 on the CRS309 instead of 7.6. (Guess it's time to get glasses.)
Have you tried setting it to 2.5Gbps or 10Gbps without auto-negotiation? When I'm done with my outside work today, I'll have to take one of those and try it on a 309 in the lab.
berzerker
Tue Jan 31, 2023 11:04 pm
I tried 2.5Gbps without autonegotiation, but I haven't tried 10. I can try that and come back.
berzerker
Tue Jan 31, 2023 11:40 pm
So I just went down and tried it again, it seems to actually work on my CCR2004. However, on both my CRS309 and CRS328 I'm unable to get a link on any of the SFP+ ports. I even brought out an unopened one and that didn't work either.
berzerker
Fri Feb 03, 2023 9:04 pm
Bumping this to see if anyone has any other experience/ideas/suggestions.
Thanks!
berzerker
Thu Feb 09, 2023 11:30 pm
Another bump, any feedback from 'Tik?
r00t
Long time Member
Long time Member
Fri Feb 10, 2023 12:12 am
If you want to see any official feedback, contact Mikrotik support directly.
But don't expect any quick fix, unless it's something really trivial. Then it might be fixed in one or two next ROS versions...
If you need this working ASAP for a job, get a supported transceiver instead.
iustin
Fri Mar 17, 2023 5:25 pm
I'm interested as well. Did anyone manage to get these working? They worked out-of-the-box in a Intel X520-DA2, I thought they'll just work on Mikrotiks, but CRS309/310 seem to see them (I can see the model, vendor, etc.) but no link, in either autoneg or forced 10G. Running 7.8.
berzerker
Fri Mar 17, 2023 5:35 pm
I have a ticket open with Mikrotik in which they said they wanted to fix this and I provided them some logs and audit info for them to look into it. I haven't heard anything from them though, but I imagine it's on the table for the next update(s).
OT: You said yours worked in an X520-DA2, what OS were you using them on, and did you have to do any mods for it to work?
iustin
Fri Mar 17, 2023 5:41 pm
Thanks, I raised a ticket too, will see.
As to the X520: stable Debian, custom kernel (5.10) but no mods, just took out S+RJ10, put this in, instant link. They don't support temp nor voltage monitoring (under Linux, at least), but I can actually hold my finger onto it, whereas with the S+RJ10 I couldn't.
r00t
Long time Member
Long time Member
Fri Mar 17, 2023 7:23 pm
That's good to know it works in X520 without any problems. I was looking for alternative to S+RJ10 because that runs as hot as fusion reactor... and X520 under full load is already plenty hot even with fan. So might give this one a try.. at least for X520 for now. Having it supported by ROS would be even better, running multiple S+RJ10s in a switch is horrible... you can feel the heat radiating from the SFP modules!
the2masters
Fri Jun 16, 2023 10:20 am
Did anyone retest with newer routeros, 7.10?
rextended
Fri Jun 16, 2023 2:09 pm
Go, and test yourself.
olivier2831
Fri Jun 16, 2023 2:25 pm
IMHO, having on the market, a 30$/€ SFP or SFP+ module supporting 1Gb/s or 2.5Gb/s would be very interesting if it can avoid such heat issues.
If my memory serves me right, reducing speed from 10Gb/s to 2.5 Gb/s is not so easy "in an autoneg world" so if you ever meet some issue on a remote site, replacing a S+RJ10 with one such 2.5 Gb/s SFP/SFP+ module can help.
iustin
Mon Jun 19, 2023 11:55 pm
Did a quick test - one CRS310 with S+RJ10, another one with the Ubiquity, both in autoneg - doesn't work. "RX loss" is shown all the time.
the2masters
Tue Jun 20, 2023 8:15 am
Thank you! I'm about to upgrade my home network to 10gbit, but have to use a few copper links. I started with a netpower 16p and S+RJ10, but this is running way to hot. I won't buy more S+RJ10 but wait until mikrotik releases a better sfp+ RJ45 adapter or supports the ubiquity one. This is a home network, I can wait :-)
mkx
Tue Jun 20, 2023 3:14 pm
If you can pull cat6e (or cat7) UTP cables, then you could pull FO cables as well. And optical SFP modules generally don't suffer from the excessive heat generation problem. Plus the range is much longer.
mbovenka
Tue Jun 20, 2023 3:49 pm
+1 for fiber. If you need new cable anyway, pull multimode fiber. The SFP+ modules are a lot cheaper and far less hot, and the cabling costs roughly the same and is easier to handle to boot.
the2masters
Tue Jun 20, 2023 9:58 pm
I have to use 2 Cat7 cables which should carry 10gbit, one is buried in the ground for 20m, the other goes through concrete (unfortunately without conduit so I can't replace it). Those were the first cables I installed, now I found fs.com and I really like their FTTA fiber optic cables, supplied ready with plugs. Cheaper than Cat7, strong and perfect for indoor and outdoor unprotected installation. Singlemode cables seems to be cheaper than multimode and can easily transmit 100gbit and more. Transceivers cost about the same, so I went with singlemode.
I started with S-31DLC20D transceivers for 1Gbit, but for 10gbit the S+31DLC10D 10gbit is unfortunately discontinued (why??). So I tried the transceivers from fs.com, #29901 for Dual Speed 1gbit and 10gbit, working great here at 1gbit (need to replace the rb2011 to update to 10gbit). Combined with the heat of the S+RJ10, I should have gone with their "industrial" transceivers that work at higher temperatures (#153818). They even have transceiver which work with single mode and multimode (#158596). Maybe mikrotik should source their transceivers from fs.com ;-)
r00t
Long time Member
Long time Member
Tue Jun 20, 2023 10:41 pm
Yeah, it really sucks SFP+ and fiber in general is not more widespread as it's clearly superior. But good luck finding non-server motherboard with SFP+ instead of metallic 10GbE, even in $500+ range. Fiber is still seen as premium and server only by manufacturers, but in reality 2nd hand SFPs are dirt cheap, same for patch cables etc. ... but I guess everybody on this forum knows all this. It's just annoying in general, especially when you don't have a choice...
</rant>
olivier2831
Wed Jun 21, 2023 7:45 pm
I thought FO is harder to deploy than copper as:
you can't easily pull a FO along its connector end within small conduits (20mm diameter or so)
FO required minimum bend radius
you can't pull the FO cable with the same strength
Which FO cable would work around the above limitations ?
the2masters
Wed Jun 21, 2023 10:05 pm
I always use the small LC connectors, they are slightly smaller than RJ45 connectors. The fiber cable is thinner than CAT7 cables, so you can put several cables in a 20mm conduit. You can even split the LC connector and put one piece a little behind the other, then the connector will have a minimal size. (but don't bend the second fiber too much, wrap it around the other strand). It is also possible to use special transceivers which only need one fiber for rx+tx on different wavelengths, then you save even more space. Or you can use 0.9mm cable and a field assembly connector....
I usually push a pull wire through the empty conduit, then I attach the fiber cable to it with thin tape and protect the connectors with it. Then I pull it through the conduit, sometimes it helps if a second person pushes the fiber into the conduit on the other side. This is the same for CAT7 and fiber optic cables, but fiber optic cables are easier to pull in my opinion.
There are many different types of fiber optic cable with different strengths and bend radii. I think the minimum bend radius of thin fiber optic cable is about the same as CAT7, but CAT7 is more robust, it doesn't break completely if you bend it a lot. But 10GBe probably won't work if you bend it too much. I bent a knot in a fiber optic patch cable, from a diameter of 2cm the signal at the receiver got worse, but the value got better after loosening the knot (but not as good as before). CAT7 also loses performance if you bend it a lot, but you can only measure that with professional equipment. With fiber cables, I don't need professional equipment to test the cables, I can just check the tx/rx power on the connected transceivers.
In my house, I use standard and very cheap fiber patch cables when it is easy to run the cable. For complicated cases and outdoor I use FTTA cables from fs.com, they are strong and robust enough for me (400N). You can even buy stronger industrial or military cable if you want.
One big argument against fiber: POE is impossible. But in case of a lightning strike it's a big advantage, because the overvoltage won't destroy all other connected devices.
olivier2831
Mon Jun 26, 2023 10:21 am
Thank you very much for this very informative reply.
McKajVah
Fri Jul 07, 2023 7:29 pm
Yeah, tried it my CRS328-24P-4S+ and they are not working. Running latest RouterOS v7.11beta4. Really disappointing as these are only 1.9W and run much cooler than the usual 3W parts.
I'll make a support ticket as well.
McKajVah
Sat Aug 19, 2023 11:34 am
Well.
I've been in contact with support on this and can now happily report as of latest version v7.11, for me this is now working!!!
No more RX Loss.
I did not see any mentioning of it in the changlog, but it's working now.
Great work Mikrotik.
berzerker
Sat Aug 19, 2023 6:13 pm
Latest 7.11 release? And what switch are you using?
I just tested this with 7.11 release version and mine are still not working. I suspect this may have to do with mine being EA models at this point, but not sure.
Edit: well it does actually work in my CRS328, but not in my CRS309. Not sure what's going on there.
the2masters
Tue Aug 22, 2023 1:22 pm
I tried it right now, in Netpower 16p it doesn't work. I tried 7.11 and 7.12-beta1, It always signals RX loss. Do you have a ticket number? Then I‌ can reference it when contacting support.
/interface ethernet monitor sfp-sfpplus2
# 2023-08-22 12:20:10 by RouterOS 7.11
# software id = 3VVI-W6C1
                             status: no-link
                   auto-negotiation: failed
                        advertising:
           link-partner-advertising:
                 sfp-module-present: yes
                        sfp-rx-loss: yes
                       sfp-tx-fault: no
                           sfp-type: SFP/SFP+/SFP28
                 sfp-connector-type: RJ45
  sfp-link-length-copper-active-om4: 100m
                    sfp-vendor-name: Ubiquiti Inc.
             sfp-vendor-part-number: UACC-CM-RJ45-MG
                sfp-vendor-revision: U07
                  sfp-vendor-serial: AK23017502216
             sfp-manufacturing-date: 23-01-28
                    eeprom-checksum: good
                             eeprom: 0000: 03 04 22 10 00 00 00 20  40 04 80 06 67 00 00 00  .."....  @...g...
                                     0010: 00 00 64 00 55 62 69 71  75 69 74 69 20 49 6e 63  ..d.Ubiq uiti Inc
                                     0020: 2e 20 20 20 00 24 5a 4c  55 41 43 43 2d 43 4d 2d  .   .$ZL UACC-CM-
                                     0030: 52 4a 34 35 2d 4d 47 20  55 30 37 20 03 52 00 e9  RJ45-MG  U07 .R..
                                     0040: 00 00 00 00 41 4b 32 33  30 31 37 35 30 32 32 31  ....AK23 01750221
                                     0050: 36 20 20 20 32 33 30 31  32 38 20 20 00 00 08 91  6   2301 28  ....
                                     0060: 00 00 00 00 00 00 00 00  00 00 00 00 00 00 00 00  ........ ........
McKajVah
Wed Aug 23, 2023 9:50 pm
Hi.
Support ticket is SUP-121423. I had some initial back and forth communication with them, but then they went silent. This was on a CRS328-POE switch.
In the meantime it seems they fixed the problems (either by actually looking into it, or I just got lucky that fixing something else also fixed this issue. Who knows...).
I reported back to them that my issues are now fixed, but still no reply.
Hopefully they can solve your issues as well as I think these run quite a bit cooler than my other versions.
berzerker
Wed Aug 23, 2023 9:51 pm
They did fix it on the 328, but it's still not working on my 309. My ticket is also silent with replies. Hopefully they'll address it in the next couple versions.
F1le
Thu Sep 14, 2023 4:33 am
No more RX Loss.
I was trying RB5009 + this UACC-CM-RJ45-MG on 7.11.2 and nope. It can see it, but nothing can be negotiated (1000Mbit/s on the other side), even if I put manual speed, also doesn't work.
iustin
Mon Oct 02, 2023 2:22 am
Just checked with 7.12 beta 9 and still the same. Why why did they fix it only on some models…
the2masters
Fri Nov 03, 2023 5:24 pm
7.12rc5 has changes to 98DX226S switch chip. I tried it on Netpower 16p, UACC-CM-RJ45-MG still does not work, always RX Loss detected.
iustin
Wed Nov 15, 2023 11:45 pm
For what is worth: after waiting and waiting, I gave up and searched for a different, low-power RJ45 transceiver. I bought one from fs.com (SFP-10G-T100, part number #154925, chipset Broadcom, and marked as Power: ≤1.8W) and that just worked when plugged into a CRS309. On the other end is a S+RJ10 for now (I immediately ordered a few more from fs.com).
This is clearly more efficient than the S+RJ10:
  • it doesn't burn my finger when I touch it :D
  • the "cpu temperature" has decreased by 1-2 celsius since then
The transceiver itself doesn't have a temperature sensor, but as the S+RJ10 was reporting ~85 celsius before I took it off, and this not burning me, I'm sure there's a large difference.
Now I'm stuck with a few Ubiquity ones that don't seem to get any traction, sigh.
spippan
Thu Nov 16, 2023 1:10 am
fs.com from my expirience is by far better than UBNT ...
their fiber cables and (Q)SFPs are a price/performance no-brainer and you can even rebrand them if needed (got them introduced at work and running a bunch of 100G QSFPs in cisco n9k 9364C and a bunch of sfp+ with FC on SM and MM and some copper sfp and sfp+ from fs.com .... running really smooth)
liyanage
Sat Jan 20, 2024 9:14 pm
This looks great, but I have to ask, did you really pay $139 per adapter? That's what it's listed for at fs.com right now (the 100m version, which seems to be the only one with the low 1.8W rating)
army1349
Mon Jan 22, 2024 5:31 pm
Hi everyone.
Any change for UACC-CM-RJ45-MG on ROS 7.13?
Thanks!
iustin
Mon Jan 22, 2024 10:11 pm
I did :( Yes, it's expensive, but also it was the easiest (and possibly the cheapest) way to solve the one link I need at 10G over copper.
liyanage
Mon Jan 22, 2024 11:00 pm
OK, thanks for confirming, and thanks for the hint about the product in the first place!
liyanage
Thu Jan 25, 2024 6:35 am
Another question, if I may. I ordered this adapter as well but when I plugged it into the SFP+ slot on the CRS309, it does not link up. I also have an S+RJ10 on the other side. I can see the vendor/serial info etc. in the SFP tab, but it won't connect.
Did you do anything else when you started using it in the CRS309?
iustin
Thu Jan 25, 2024 12:32 pm
Initially no, but after the most recent version (7.13), I need to force link speed to fixed. I haven’t tried mixed, only same transceiver on both ends, both with fixed
liyanage
Fri Jan 26, 2024 7:14 am
I am on 7.13 and I can confirm that it does indeed start to work for me when I turn off auto-negotiation and configure the speed manually. It did not work with different adapters on both ends, I had to use two of the FS ones. Now I'll see how much cooler they run.
I wonder if disabling auto-negotiation would also make it work for the Ubiquiti ones.
Thanks again for the tips!
liyanage
Mon Jan 29, 2024 6:33 am
I filed a support ticket with MikroTik requesting that they fix that issue and fully support this FS.com module. The support case number is SUP-142140.
army1349
Thu Feb 29, 2024 10:44 pm
Anyone able to test UACC-CM-RJ45-MG with ROS 7.14? Thanks!
Users browsing this forum: clambert, GoogleOther [Bot], intania, oskarsk, phascogale and 203 guests
