ourplan
Radius Queue Problem
Mon Jan 30, 2023 8:08 pm
Hello there.
I don't want queue to be applied to ppp users sent by radius. automatically writes a queue rule for every connection request. I made kind=none for the default in the Queue types section, but this time when a new connection request comes in, it gives the warning "could not add queue: download-queue kind=none not allowed (6)" and ppp cannot be active.
tdw
Re: Radius Queue Problem
Mon Jan 30, 2023 11:45 pm
A queue is created if the RADIUS Access-Accept message contains one or more Rate attributes, configure your server not to send any.
ourplan
Tue Jan 31, 2023 11:35 am
Thanks for the information, but I want to do this on some nas devices. Isn't there a setting on Mikrotik to remove the limitation?
My main goal is to have no ppp entries in the queue table, so I want to gain cpu.
tdw
Tue Jan 31, 2023 10:14 pm
No. Configure the RADIUS server to only send rate attributes to the NAS where you want to use them.
AidanAus
Thu Feb 02, 2023 7:43 am
please note that the Mikrotik will use the queue to keep track of usage etc, if none is set for a user the accounting will no longer work correctly.
ourplan
Sat Feb 04, 2023 12:47 pm
I'm requesting help on how to do this on Mikrotik instead of the server. I don't want to use speed profiles, so no records are created on the queue side. As I mentioned before, my goal is to minimize CPU usage.
chechito
Sat Feb 04, 2023 3:22 pm
you can write a script to periodically disable queues, you can use certain conditions to choose which queues to disable
Users browsing this forum: mkx and 194 guests
