drasir
Please remove SSL requirement for REST Api
Tue Jan 31, 2023 12:13 am
I am working on a client side website tha displays active firewall connections on a worldmap. To keep it as simple as possible, i am using plain JS and the REST Api.
This is intended for LAN Use only, i don't understand why i am forced to hassle with SSL. Self Signed Root_CAs etc. are not a problem, but the normal api has unencrypted access, why doesn't REST?
A bit counterintuitive for RouterOS to be restricted in that way. Please let me access REST via Plain HTTP, i am totally capabale of locking of access by myself.
normis
Re: Please remove SSL requirement for REST Api
Tue Jan 31, 2023 8:40 am
said every hacked user ever :D
P.S.: I will look into it, although usually downgrading security for sake of "less hassle" is not a good idea
drasir
Tue Jan 31, 2023 1:30 pm
I get your point, sure. However, whole of RouterOS's excellence is (in my eyes) the ability to decide for myself. I could open Webfig to WAN, could run without any Firewall rules whatsover etc.
I think even stdcfg is considered "unsafe" by most or even better, setting up device without config at all. ALL doors wide open.
So the reasoning especially for this one to be cut off, and that after the fact that i first have to enable API anyhow appears somewhat strange.
Amm0
Wed Feb 01, 2023 3:52 pm
Although it seems a bad idea in most cases, OP is right it's not consistent. webfig allows an unencrypted password.
But I just think it be better if "rest" was it own thing under /ip/services (e.g. perhaps allowing different port, cert or no cert, send CORS headers, etc.) . Or perhaps, if the existing www and www-ssl allows more configurations (e.g. checkboxes to enable REST vs webfig, CORS, etc.) – either way works IMO, mainly a few more options on the web server's exports.
I say this since there is likely also the cases where someone may want webfig but NOT rest, or reverse: rest but no webfig.
Amm0
Wed Feb 01, 2023 4:09 pm
But that's a big unfair. Most of the routers for home/SMB include a decent firewall on WAN port. And unsecured (HTTP) webfig is enabled on LAN side only.
Now I wouldn't be surprised if EU regulations required secured access to configure at some point in future. And, it's not that hard to generate a self-cert. which allow you to move on your code to that use the REST (likely with some parameter in your calling code to ignore untrusted certs).
Larsa
Wed Feb 01, 2023 4:55 pm
REST API over https is also extremely slow on LHG, SXT, and similar devices.
Before a possible porting of our mikrotik LTE monitoring agents to REST API, we carried out some pretty extensive tests, but due to the above problems, we decided to stick with the old API.
normis
Wed Feb 01, 2023 5:08 pm
The main risk is that authentication credentials can be read with passive eavesdropping, no need to intercept and modify packages. If data is sent over a hub or the admin is storing traffic headers for logging purposes, the password can land in unexpected places.
WebFig over HTTP does some encryption and even SwOS uses Digest access authentication to at least hide passwords.
This would be a whole new level of unsecure, compared to HTTP
Larsa
Wed Feb 01, 2023 5:45 pm
Well, it's nice to hear you are picky regarding the security in this case! ;-)
However, I don't think that people in general consider WebFig/SwOS and the old API to be secure, right? Thus, why not let the developer/user to decide what should be used or at least try to optimize the encryption model so it's usable on endpoint devices where the large number of units are found (ie PTMP, PTP, AP, LTE, etc).
drasir
Wed Feb 01, 2023 6:01 pm
But I just think it be better if "rest" was it own thing under /ip/services (e.g. perhaps allowing different port, cert or no cert..)
Think so too. That is mostly the main point of my post: Give the user more options. Nobody is stoping me from enabling webfig WAN access and set "admin / admin" as credentials, or enabling telnet access which would also send login credentials as plain text right? - why would i be stopped here?
MakroTok
Wed Feb 22, 2023 12:02 pm
It would be very much appreciated if this requirement gets dropped. It adds additional burden on people just wanting to "play" with the REST API.
For people who want to secure their network, I guess they wouldn't consider to activate telnet or www at all.
For the rest of us, please let us do some stuff without too much of a hassle ;)
If REST would get to be a dedicated service, even better, then settings such as CORS might become an option, too.
Amm0
Wed Feb 22, 2023 5:59 pm
Agreed.
But I do think improving the "Let's Encrypt" support to allow different auth method would also help this "quickest path to playing with REST" use case.
A broader definition of:
/certificate/enable-ssl-certificate
could, optionally, generate a self-signed certs to make HTTPS work — the "enable-ssl-certificate" command name kinda implies it should help more with HTTPS than it does :? ...
MakroTok
Wed Feb 22, 2023 6:37 pm
Definitely. Make it simpler to turn HTTPS on, would allow much faster adoption, then all the hoops and loops (I know I'm exaggerating a bit, but it's really inconvenient).
Sob
Wed Feb 22, 2023 6:49 pm
If self-signed certificate would be enough for you, it's not like it's too difficult to get it now:
/certificate add common-name=router.example.net
/certificate sign router.example.net
it's still inconvenient, because you need to either make the client trust it or ignore it, but it shouldn't be a show stopper.
Amm0
Wed Feb 22, 2023 7:19 pm
In most language HTTP client libraries, they all force certificate checks – all different ways to disable, and some don't use the OS's trust store, adding more complexity with self-signed.
Do think improving somehow the "/certificate/enable-ssl-certificate" to more likely be able to get some certificate solve the more general problem – e.g. you want TLS but it ain't exactly easy – quite of few steps beyond even RouterOS.
If a container wanted to communicate back to its host, I don't think HTTP is a bad option. And unsecured traffic allow packet sniffing to better troubleshoot issues in the calls (& with TZSP could watch it live in Wireshark from the dev PC).
Anyway a checkbox for "Allow REST" in the /ip/service for www wouldn't be bad as an initial step.
Sob
Wed Feb 22, 2023 7:48 pm
Don't get me wrong, I'm all for letting people decide. If someone wants unencrypted REST, is should be their choice. I'm also big fan of configurable things. Currently you can enable web server and it's all or nothing (WebFig, REST, ...) => not good. Same for current enable-ssl-certificate, it's hardcoded shortcut with zero flexibility.
Amm0
Wed Feb 22, 2023 8:39 pm
Generally a fan of more knobs to turn myself. So certainly wasn't arguing against a "Use Webfig" at the same time on both www/www-ssl... :lol:
But in any case REST should NOT be a default on www.
Users browsing this forum: deadmaus911 and 15 guests
