JasonSauceTV
RB5009 LAN port down/up state
Wed Feb 01, 2023 9:07 am
Hey everyone. Just bought a rb5009ug+s+in. Firmware and routerOS are both on 7.7. Small issue I'm having and having trouble finding anything on the forums. Every 10 mins my lan port goes into a link down, then up state, disconnecting me from winbox and dropping internet to that port. I'm using ppooe login for CenturyLink fiber with vlanID 201. Has anyone seen anything that could potentially fix this issue? My cat5 cable is confirmed working. I tried ether2 and ether 3,4,5,6,7,8 ports to rule out a fouled port. Out of ideas and I am not ready to fully deploy the router yet until this issue is corrected. Thanks.
Tried 3 different working cat5e cables. tried different ports on the router.
TIA
elbob2002
Re: RB5009 LAN port down/up state
Wed Feb 01, 2023 9:33 am
Try disabling Auto Negotiation on your LAN port and setting it to 1Gbps
JasonSauceTV
Wed Feb 01, 2023 10:22 am
I did that as well. Set it to 1gb. It dropped faster. Within 3 mins or instantly.
bkyakch
Fri Sep 29, 2023 5:34 pm
Hey, the same issue occurred with mine MIkrotik 5009. Did find out the root cause?
JasonPI
Thu Oct 26, 2023 12:42 am
Just posting in hopes it will help someone in the future. I purchased RB5009UG+S+in. I had set up my WAN port on ether1 (2.5 Port) and attached my LAN on ether2 (1GB Port). Very simple configuration with a dhcp being served by the router. Everything was working but every 10 minutes or so the I would lose connectivity. I checked the logs and it was exactly as described above. My ether2 port kept going down then immediately come back up. I tried disabling Auto Negotiation on the Lan port. I adjusted the dchp settings. Nothing worked. The device attached to ether2 was a ScreenBeam MoCa 2.5 network adapter. It was attached through coaxial to 2 other MoCa 2.5 adapters. I Moved my WAN port to ether5 (1GB Port) and moved my LAN port to ether 1 (2.5 Port). It has been 24 hours and both ports have remained connected. I am assuming the router and the MoCa device were not able to negotiate to 1GB or the MoCa device kept trying to negotiate to a faster speed.
kalapuro
Mon Nov 20, 2023 6:39 pm
Thanks mate, got exactly the same issue with MoCA and RB5009UG! Will try your solution now!
kalapuro
Tue Nov 21, 2023 11:20 am
Thanks again! It started to work as expected. You saved me a lot of hours )
Users browsing this forum: Bing [Bot] and 93 guests
