qatar2022
2 IPS Aggregation
Wed Feb 01, 2023 9:11 am
Dear all
I have a question regarding Aggregation.
now I have 2 Huawei 4g CPE router and each one has 500mb DL so total 1GB DL
and I have MT RB5009 and I'm using NTH failover but the speed around 480mb
I watch serval video on YouTube about bonding that can do Aggregation to get full speed from both ISP router. or just use bonding between 2 or more MT devise
regards
AidanAus
Re: 2 IPS Aggregation
Thu Feb 02, 2023 7:20 am
The only way that you will see 1gb through a speed test is if you bend the interface and to establish a bond it must be set up from both sides of the link.
the load balancing is just that, you are pushing traffic out one OR the other gateway depending on the logic you have implemented.
If you realy want the aggregated speed for some reason you can do this by getting a CHR in the cloud then either using a vpn with an eoip tunnel or just an eoip tunnel into the CHR, bond the eoip interfaces then set your default route to go out the band interface :)
Users browsing this forum: aferreira, Bing [Bot] and 172 guests
