atomicduck
Doesn't RB5009 have a serial port??
Wed Feb 01, 2023 11:58 am
I just (finally) received RB5009, and I see no serial port? Am I missing something?
rextended
Re: Doesn't RB5009 have a serial port??
Wed Feb 01, 2023 12:01 pm
Yes, you missed reading the specs before buying it.
atomicduck
Wed Feb 01, 2023 12:07 pm
Excellent. Is there a way to access the device over USB port via serial adapter or something??
woland
Wed Feb 01, 2023 12:18 pm
rextended
Wed Feb 01, 2023 1:52 pm
Do not work on v7, see other topic about that.
atomicduck
Wed Feb 01, 2023 3:00 pm
But this doesn't connect to serial console? It is only for running routeros devices?
atomicduck
Wed Feb 01, 2023 3:12 pm
Could you please provide me the with the thread link? I can't find it.
This said, 5009 is a great device, but without serial I can't implement it anywhere as there is no backup access.
rextended
Wed Feb 01, 2023 3:23 pm
try to write WOOBM v7 on Search... and press ener....
Backup for what? For have serial port onsite or use remotely the serial port?
atomicduck
Wed Feb 01, 2023 3:28 pm
[/quote]
Backup for when routeros is broken so I can fix it tru console.
woland
Wed Feb 01, 2023 3:41 pm
Thanks, there might be issues, but on my HAPac2 it does work well with v7, just tested it, could connect via WOOBM:
[admin@ut-r1] /system/routerboard> print
       routerboard: yes
        board-name: hAP ac^2
             model: RBD52G-5HacD2HnD
     serial-number: E5780F4848A2
     firmware-type: ipq4000L
  factory-firmware: 6.45.9
  current-firmware: 7.8beta2
  upgrade-firmware: 7.8beta2
bpwl
Wed Feb 01, 2023 3:45 pm
Must be 5009 then, as hAP ac3 ROS V7 is no problem.
rextended
Wed Feb 01, 2023 3:48 pm
What firmware have your WOOBM? (on bottom of the settings page)
woland
Wed Feb 01, 2023 4:08 pm
I put my WOOBM already away, but I know I have installed the file: woobmfw_211105.bin
That file is still on my laptop...
rextended
Wed Feb 01, 2023 4:10 pm
:/ I hope on more recent version that fix the issue....
Amm0
Wed Feb 01, 2023 4:21 pm
I get where your coming from – want to get in if the router is FUBAR...
But winbox's MAC-address / layer2 access is a godsend to avoid needing a serial port to access the router if you're at the physical router. If you enable RoMON, Layer2 access get extended to other routers using an alternative switching plane.
I don't have any handy, but I'd image a USB to serial adapter work if it showed up under /port... Then it could be assigned to console in /system/console – before you'd needed for an "emergency". Just plugging in the serial-to-USB is likely going to do nothing since RouterOS wants you to assign the port to some service, of which console is one possibility.
bpwl
Wed Feb 01, 2023 4:26 pm
My version v1.1.
Once had a problem on hAP ac2 , with the already defined system/console. Deleting console solved the problem.
EDIT: with some luck and fail-safe RouterOS design :-) .
https://wiki.mikrotik.com/wiki/Serial_Port_Usage
"as RouterOS will recreate the console after the next reboot when you really remove it."
"When rebooting a RouterBoard the bootloader (RouterBOOT) will always use the serial console (serial0 on RouterBoards) to send out some startup messages and offer access to the RouterBOOT menu."
atomicduck
Wed Feb 01, 2023 4:49 pm
I got a reply re connectivity -> USB-serial-nullmodemcable-serial-usb contraption should work no problems.
I just ordered another usb adapter I know works fine and I tested over USB connection.
As for woobm I am still not sure if that is console connection or terminal connection.
jbl42
Wed Feb 01, 2023 9:32 pm
What I do on "important" RB5009 is to sacrifice ether8 for mgmt port. I make it not part of the main bridge nor part of the LAN interface group and bind a static ip directly to ether8, allow winbox/webui/ssh on it. So if I mess up bridge settings or FW rules in a way not even MAC access is working, I can connect an Ethernet cable to ether 8.
But as long as RB5009 is still booting, MAC access usually works also for worst config mishaps.
And there is always safe mode which should be activated before changing bridge/IP/FW settings.
r00t
Long time Member
Long time Member
Wed Feb 01, 2023 9:53 pm
It can be made even easier from two USB to TTL boards (super cheap from China, <$1, just get FTDI chips as they are least problematic), connect RX->TX, TX->RX, GND->GND and it's done. Easiest OOB management from one Mikrotik to another.
WOOBM contains ESP8266 MCU for dealing with wifi/serving web pages and USB to UART module so it appears as USB serial device/adapter on Mikrotik.
So it's USB serial console terminal with WEB UI.
atomicduck
Wed Feb 01, 2023 11:47 pm
I usually just enable mac access and be done with it. Password is humongous, so if someone breaks it, well - they have my permisson to wreak havoc :-D what bothers me the most is not having ability to access the actual terminal console, because that thing saved my ass not once. A month ago I had dead 4011, as in completely dead. Corrupted ssd storage. And I fixed it thru boot sector force over serial. It worked! So no serial is a deal-breaker for me. But it is not a big deal, as if I understand correctly USB is just an implementation of serial port, but I will have to test that + there is an other option of using serial adapters.
atomicduck
Wed Feb 01, 2023 11:49 pm
Not sure about TTL boards. What benefit do they bring? I need a robust solution that I will use once or never and that will always work.
As for woobm I will have to test that thing. If it works, fine! But I need to have xmodem protocol working for it to transfer bootsector.
ahmedramze
Thu Feb 02, 2023 12:34 am
you can connect any USB-RS232 and use it as console in /system ports if you have USB-HUB also you can connect many USBs devices and configure it as you like we was use it for UPS and GSM devices etc.
also there is Quad/Octa Serial ports you can connected it Router OS almost support all serial chips and in market FDS chip its available.
like this https://www.usbgear.com/USB2-8COM-M.html
Znevna
Thu Feb 02, 2023 7:36 am
While all these adapters might work (because nobody guarantees the support in RouterOS), they are non-functional if RouterOS doesn't boot, the main reason you'd want a serial connection in the first place.
So they are kinda useless.
atomicduck
Thu Feb 02, 2023 9:15 am
I am confused now - does this mean I wouldn't be able to connect to serial console using an adapter? (in usb-serial = serial-usb config)
Znevna
Re: Doesn't RB5009 have a serial port??  [SOLVED]
Thu Feb 02, 2023 9:21 am
Probably there are some stuff lost in translation.
1. You CAN use serial<>usb adapters to connect to your RouterOS, IF: that adapter is properly recognized and configured under RouterOS and if RouterOS is functional.
2. You CAN'T use serial<>usb adapters as a debug port, if RouterOS crashed for some reason and it doesn't boot: RouterBOOT has disabled serial console output on the devices that have no serial port from the factory and it's not configured to output to some random USB device anyway.
Better?
atomicduck
Thu Feb 02, 2023 9:27 am
2. You CAN'T use serial<>usb adapters as a debug port (if RouterOS crashed for some reason and it doesn't boot): RouterBOOT has disabled serial console output on the devices that have no serial port from the factory and it's not configured to output to some random USB device anyway.
Better?
Yes, it is better, but I am not happy. :-(
From what I understand, all this means that there is no way to connect to debug port on 5009? [And that I can use both adapters or Woobm to connect to to console thru USB if ROS is operational, but unaccessible (because I was stupid and blocked myself out)]
Znevna
Thu Feb 02, 2023 9:28 am
Exactly.
atomicduck
Thu Feb 02, 2023 9:36 am
Crap.
OK... So tell me this: I had a failed 4011 two months ago, as the storage got corrupted. That is the most plausible explanation of what happened to it. Netinstall did not work whatever I tried, it just got stuck on upload, so I had to reformat the storage, and reupload the routerboot that I got from MT. I did that thru serial port xmodem and the completely dead 4011 now works, here I am looking at it right now. It looks nice and happy.
Say somehting like this happens to me on production 5009, I can literally throw it away because it is bricked?
TBH I am pissed at MT now for committing serial on 5009.
Znevna
Thu Feb 02, 2023 10:03 am
That's my take on it, yes. Unless they have some secret recovery procedure, you'll have to send it back for repairs or get it replaced.
Or, void the warranty, get your hands dirty to solder a header and flip a bit in the config partition to enable serial output. But probably not worth the risk :) (not an easy job anyway).
Boo MikroTik, boo! :p
But, chances that you get a device in a state when Netinstall doesn't work are low anyway (except your lucky rb4011), so don't panic.
atomicduck
Thu Feb 02, 2023 1:35 pm
Like on the back of the The Hitchhiker's Guide to the Galaxy book. :-D
atomicduck
Fri Feb 03, 2023 11:40 am
I also got a reply from MikroTik support: both Woobm and USB-Serial adapters can work only if ROS is running, so no console for me. So I guess it better not break. LOL :-)
Znevna
Fri Feb 03, 2023 12:11 pm
No surprise :)
r00t
Long time Member
Long time Member
Fri Feb 03, 2023 4:36 pm
Soft-disabling UART console on most of the devices is one of the most stupid decisions Mikrotik made. Thanks to it devices that could be repaired are tossed into e-waste (or regular) bin for no reason. Also with no console you can't even see what's going on during netinstall. So many people are failing to do netinstall properly and it's mostly because there is ZERO debug or status output of what's happening.
It's one thing to decide not to put serial port connector on device, be it for design or cost reasons. But why disable the internal UART pins, that are right there on PCB? That may be your last way to recover the device.
There is no official reason why they do this. Never got any good answer from anyone, be it here on forum or support. Only usual "if product is not working you can RMA it" reply. Yeah, great.. and when warranty is over, then it's just supposed to be doorstop brick?! Just plain stupid. While Mikrotik is relatively friendly when it comes to repairing out of warranty devices and even doing things like NAND chip swaps, having proper console would help many devices to not need such expensive repair in a first place. In the end it's waste of everyone's time (be it support answering questions, sellers having to do extra RMAs or people who then have to repair these broken devices).
It's good idea to netboot OpenWRT and flip that config byte to enable the console as soon as warranty is over, it seems to work on all ARM devices.. that way if you happen to need it in the future, you can have bootloader console access.
atomicduck
Fri Feb 03, 2023 5:56 pm
Do you happen to have OpenWRT manual on how to do this? 5009 is ARM 64 bit which is plenty and a reason why I bought it.
r00t
Long time Member
Long time Member
Fri Feb 03, 2023 6:21 pm
Looks like on RB5009 situation is more complex. If you want to go down the rabbit hole:
https://openwrt.org/toh/mikrotik/rb5009ug_s_in
https://github.com/adron-s/aux-loader2
atomicduck
Fri Feb 03, 2023 6:45 pm
Probably not a good idea. It seems it would be very easy to brick the router this way...
I just won't use this thing in production and that's about it.
RB1100 is plenty.
Znevna
Fri Feb 03, 2023 6:51 pm
Let's make a request for MikroTik to make that setting an option? Something that can be flipped the same way other RouterBOOT settings can?
atomicduck
Fri Feb 03, 2023 7:04 pm
I support that. Even if going to the board directly if there are headers there, that would be a viable option to recover router that died. Or make header ourselves. The current way is kind of no go.
r00t
Long time Member
Long time Member
Sat Feb 04, 2023 2:05 am
+1
Enabling internal UART to be actually usable would be great. Especially for boards with no USB, where UART is only way to connect anything...
w0lt
Long time Member
Long time Member
Sat Feb 04, 2023 2:46 am
Any router that might be designed for use as a test bed or lab environment should be designed with a serial port.
The fact that the RB5009 wasn't baffles me. Initially, it looked attractive till I saw the serial port wasn't there..
Just get a RB4011 instead..
-tp
atomicduck
Sat Feb 04, 2023 8:57 am
-tp
Exactly what I did. I decided to put 5009 as a core router in my LAN, and 4011 I salvaged last month exactly thru serial console connection will be used for testing.
Having a serial port on 5009 was such a normal idea to me that I didn't even pay attention does it have it or not. I think MikroTik did this on purpose, so the people will buy more expensive (and similarly performant) RB1100AHx4. Can't really blame them tho, as 5009 is really powerful.
Users browsing this forum: Ahrefs [Bot] and 64 guests
