miankamran7100
MAC Filtering Block TTL
Thu Feb 02, 2023 8:04 am
Dear all,
Hope you will be fine. I need your help
I'm running a hotspot server with multi-vendor routers (Linksys, Cisco, ZTE ). People are sharing my internet with WiFi Scanning.
Now I want to enable MAC Filtering on the LAN port and disable the hotspot server. Every user connects with their MAC.
So MAC Filtering will stop sharing wifi from one device to another
MAC FilterLimit TTL to one device or not?
Thanks & Regards
rextended
Re: MAC Filtering Block TTL
Thu Feb 02, 2023 10:43 am
You still see only one MAC, the "Tethering" device do all the works and you can not do nothing.
Users browsing this forum: No registered users and 25 guests
