t83oleg
mikrotik disconnected, key handshake timeout, signal strength -95
Thu Feb 02, 2023 10:08 pm
Hi all
can someone tell me what this error is and where to look?
the router is located in a one-room apartment. are you kidding me? the password is correct since this situation is treated by reconnecting to the wifi network. What now?
here is my config
# feb/02/2023 22:58:07 by RouterOS 7.7
# software id = YVFU-0ZQA
# model = RBD53iG-5HacD2HnD
# serial number = E7290D7E74A8
add admin-mac=08:55:31:F6:FA:EB auto-mac=no comment=defconf name=bridge
/interface lte
set [ find default-name=lte1 ] disabled=yes
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wifiwave2 channel
add name=channel_2GHz
add name=channel_5GHz
/interface wifiwave2 security
add name=sec_2GHz
add name=sec_5GHz
/interface wifiwave2 configuration
add channel=channel_2GHz name=cfg_2GHz security=sec_2GHz
add channel=channel_5GHz name=cfg_5GHz security=sec_5GHz
set [ find default-name=wifi1 ] channel=channel_2GHz channel.band=2ghz-n \
    .frequency=2412 .skip-dfs-channels=disabled .width=20/40mhz \
    configuration=cfg_2GHz configuration.country=Russia .mode=ap .ssid=\
    MikroTik-F6FAEF_2GHz .tx-power=17 disabled=no name=wifi_2GHz security=\
    sec_2GHz security.authentication-types=wpa2-psk,wpa3-psk \
    .group-key-update=1h .wps=disable
set [ find default-name=wifi2 ] channel=channel_5GHz channel.band=5ghz-ac \
    .frequency=5180 .skip-dfs-channels=disabled .width=20/40/80mhz \
    configuration=cfg_5GHz configuration.country=Russia .mode=ap .ssid=\
    MikroTik-F6FAF0_5GHz .tx-power=17 disabled=no name=wifi_5GHz security=\
    sec_5GHz security.authentication-types=wpa2-psk,wpa3-psk \
add name=dhcp ranges=192.168.88.10-192.168.88.254
add address-pool=dhcp interface=bridge name=defconf
add bridge=bridge comment=defconf interface=wifi_2GHz
add bridge=bridge comment=defconf interface=wifi_5GHz
set discover-interface-list=none protocol=""
add interface=lte1 list=WAN
    192.168.88.0
/ip dhcp-client
    192.168.88.1
set allow-remote-requests=yes
/ip dns static
    established,related,untracked
    invalid
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip service
set telnet address=192.168.88.0/24 disabled=yes
set ftp address=192.168.88.0/24 disabled=yes
set www address=192.168.88.0/24
set ssh address=192.168.88.0/24 disabled=yes
set api address=192.168.88.0/24 disabled=yes
set winbox address=192.168.88.0/24
set api-ssl address=192.168.88.0/24 disabled=yes
/ip upnp
set allow-disable-external-interface=yes enabled=yes
/ip upnp interfaces
add interface=bridge type=internal
add interface=ether1 type=external
/ipv6 firewall address-list
/ipv6 firewall filter
    invalid
    icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
    33434-33534 protocol=udp
    udp src-address=fe80::/10
    protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
    icmpv6
    500,4500 protocol=udp
    ipsec-ah
    ipsec-esp
    !LAN
/system clock
set time-zone-autodetect=no
/system clock manual
set time-zone=+03:00
/system leds settings
set all-leds-off=immediate
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.ru.pool.ntp.org
add address=1.ru.pool.ntp.org
add address=2.ru.pool.ntp.org
add address=3.ru.pool.ntp.org
/system script
add dont-require-permissions=no name=script1 owner=chudnoechudo policy=\
    ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon source="/\
    ip firewall mangle\
    \n add chain=forward action=change-mss new-mss=clamp-to-pmtu passthrough=n\
    o tcp-flags=syn protocol=tcp in-interface=ether1 tcp-mss=1300-65535 log=no\
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
hope help)
Reason: Use proper tags: quote to quote, code for code - keep forum tidy
nichky
Re: mikrotik disconnected, key handshake timeout, signal strength -95
Fri Feb 03, 2023 4:59 am
try this:
upgrade to the latest version
width=20 (both)
frequency= Freq.Usage - fine the best channel (both)
t83oleg
Fri Feb 03, 2023 9:46 am
5 meters from the router, turn on the channel width of 20, but then we need 40 and 80, and for that kind of money, if you don’t use all the functionality, why then do it for the house, then they would do it for offices and powder their brains for everyone .... it remains only to say mikrotiku nakidate in vrotik)))) crutches are made shorter all the time!!!
nichky
Fri Feb 03, 2023 11:26 am
what is the outout on that, any issus?
t83oleg
Fri Feb 03, 2023 12:35 pm
unfortunately the situation has not changed for the better
optio
Long time Member
Long time Member
Sat Feb 04, 2023 9:24 pm
I also had issues with 5Ghz, problem was interference with other frequencies. ROS automatic frequency selection did not help, so I used application (inSSIDer on MacOS) to scan wifi channels and found best channel which will not overlap with channels in range.
See table https://en.wikipedia.org/wiki/List_of_W ... j/n/ac/ax) for finding which frequency belongs to channel.
Find best channel and set it's frequency manually.
My wlan settings for channel 60:
 5  R ;;; 5 GHz
      name="wlan2" mtu=1500 l2mtu=1600 mac-address=<mac_addr> arp=enabled interface-type=IPQ4019
      mode=ap-bridge ssid="<ssid>" frequency=5300 band=5ghz-onlyac channel-width=20/40/80mhz-eeCe
      secondary-frequency="" scan-list=5290-5310 wireless-protocol=802.11 vlan-mode=no-tag vlan-id=1
      wds-mode=disabled wds-default-bridge=none wds-ignore-ssid=no bridge-mode=enabled
      default-authentication=yes default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
      hide-ssid=no security-profile=eap-tls compression=no
Promets
Sun Jul 09, 2023 11:52 pm
the problem still continues
Version 7.10.1
dgallentine
Fri Oct 13, 2023 6:38 pm
Also seeing this issue still. Have on multiple AX2's from 7.6 up to 7.10.1. Waiting to see if it continues with 7.11, haven't gotten any feedback yet.
K0NCTANT1N
Wed Oct 18, 2023 1:26 pm
1. Upgrade in 7.11.2
2. Accusations no place in this community
3. If you don't know how, don't try it
4. Find information for example in YouTube, available in Russian
Users browsing this forum: No registered users and 46 guests
