IwanGreyling
redirecting friendly.url.com/whatever to a local.ip:port
Fri Feb 03, 2023 11:21 am
Hey guys! I have some services running on my local server on different ports and I want them to be redirected to a friendly.url.com/whatever.
I have no idea what something like that is called and what I should be looking for...
I know it's not possible in the URL DNS Entries as I've been told. So... Can someone point me in the right direction?
jvanhambelgium
Forum Veteran
Forum Veteran
Re: redirecting friendly.url.com/whatever to a local.ip:port
Fri Feb 03, 2023 11:29 am
Not possible with Mikrotik.
If your MT supports "containers" you can consider trying to get something like NGINX/Traeffix etc active and "redirect" from there.
You need a reverse-proxy of some sort for these functions and MT does not have it embedded.
IwanGreyling
Fri Feb 03, 2023 12:04 pm
Hey! Thanks for your reply and advice.
I think the RB3011 does support containers? I'll look it up. But just knowing what to search for is already a huge leap forward!
own3r1138
Long time Member
Long time Member
Fri Feb 03, 2023 12:27 pm
Is the RB3011 ARM?
https://download.mikrotik.com/routeros/ ... 8beta2.zip
I couldn't get the Traefik to work on MT. I think Nginx Proxy will work.
https://nginxproxymanager.com/
IwanGreyling
Fri Feb 03, 2023 12:29 pm
Yep! Rb3011 is ARM
Users browsing this forum: Bing [Bot], zabloc and 28 guests
