lurch
changing port pvid via command line
Fri Feb 03, 2023 1:03 pm
I'm after a one liner to change the bridge port pvid via ssh but can't figure out the correct command i'm after something like
interface/bridge/vlan/set port=ether5 vlan=10
does anyone know the correct command to use?
rextended
Re: changing port pvid via command line
Fri Feb 03, 2023 1:21 pm
do
/interface bridge export
and post on forum the results with description of what you want change on that config... ;) ;) ;)
lurch
Fri Feb 03, 2023 1:33 pm
I want to change the pvid at the end
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5 pvid=X
rextended
Re: changing port pvid via command line  [SOLVED]
Fri Feb 03, 2023 1:56 pm
/interface bridge port set [find where bridge=bridge and interface=ether5] pvid=<X>
lurch
Fri Feb 03, 2023 5:12 pm
Perfect many thanks
Users browsing this forum: Bing [Bot] and 41 guests
