marcwitteveen
Slow WiFi on 5G and after changing settings - no supported channel
Fri Feb 03, 2023 1:03 pm
I have a Fiber connection of 500/100 MB, when I connect directly to my main router this speed is achieved. I also have 3 access points connected to this router, if I connect to to the device through a cable I get 500/100 as well. However when I connect it to 5Ghz WiFi, then the speed is limited. The access point is RB962UiGS-5HacT2HnT or hAP ac.
I am 2 meters away from the access point.
What can I do to fix this? Find below the configuration of the main router.
# feb/03/2023 11:36:38 by RouterOS 6.49.7
# software id = TNDT-F0VH
# model = CRS326-24G-2S+
# serial number = 945509437B23
/caps-man channel
add band=2ghz-g/n control-channel-width=20mhz extension-channel=disabled \
    frequency=2412 name="channel 1 - 2.4Ghz" reselect-interval=1h
    frequency=2437 name="channel 6 - 2.4Ghz" reselect-interval=1h
    frequency=2462 name="channel 11 - 2.4Ghz" reselect-interval=1h
add band=5ghz-a/n/ac control-channel-width=20mhz extension-channel=XX \
    frequency=5180 name="channel 36 - 5Ghz (20 Mhz)" reselect-interval=1h
    frequency=5200 name="channel 40 - 5Ghz (20 Mhz)" reselect-interval=1h
    frequency=5220 name="channel 44 - 5Ghz (20 Mhz)" reselect-interval=1h
    frequency=5240 name="channel 48 - 5Ghz (20 Mhz)" reselect-interval=1h
    frequency=5260 name="channel 52 - 5Ghz (20 Mhz)" reselect-interval=1h
    frequency=5280 name="channel 56 - 5Ghz (20 Mhz)" reselect-interval=1h
    frequency=5300 name="channel 60 - 5Ghz (20 Mhz)" reselect-interval=1h
add band=5ghz-n/ac control-channel-width=40mhz-turbo extension-channel=Ce \
    frequency=5230 name="channel 46 - 5Ghz (40 MHz)"
    frequency=5190 name="channel 38 - 5Ghz (40 Mhz)"
    frequency=5270 name="channel 54 - 5Ghz (40 Mhz)"
    frequency=5310 name="channel 62 - 5 Ghz (40 Mhz)"
add admin-mac=B8:69:F4:B5:83:E6 auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name="ether1 - OLD Modem"
set [ find default-name=ether3 ] name="ether3 - NAS 1"
set [ find default-name=ether4 ] name="ether4 - NAS 2"
set [ find default-name=ether5 ] name="ether5 - AP - Dominika"
set [ find default-name=ether6 ] name="ether6 - AP - Marc"
set [ find default-name=ether7 ] name="ether7 - AP - Living Room"
set [ find default-name=ether9 ] name="ether9 - Modem NEW"
set [ find default-name=ether17 ] name="ether17 - Elias"
set [ find default-name=ether23 ] name="ether23 - Gialt"
set [ find default-name=sfp-sfpplus1 ] disabled=yes
set [ find default-name=sfp-sfpplus2 ] disabled=yes
/caps-man datapath
add bridge=bridge name=datapath
/caps-man security
add authentication-types=wpa2-psk eap-methods=passthrough encryption=aes-ccm \
    group-encryption=aes-ccm group-key-update=5m name=default
/caps-man configuration
add channel="channel 1 - 2.4Ghz" country=slovenia datapath=datapath \
    installation=any mode=ap name="Working Room M - WiFi 1 - 2G" security=\
    default ssid=Skynet
add channel="channel 62 - 5 Ghz (40 Mhz)" country=slovenia datapath=datapath \
    installation=any mode=ap name="Working Room M - WiFi 2 - 5G" rates.basic=\
    "" rates.ht-basic-mcs="" rates.supported="" security=default ssid=\
    Skynet-5
add channel="channel 6 - 2.4Ghz" country=slovenia datapath=datapath \
    installation=indoor mode=ap name="Working Room D - WiFi 1 - 2G" security=\
    default ssid=Skynet
add channel="channel 44 - 5Ghz (20 Mhz)" country=slovenia datapath=datapath \
    installation=indoor mode=ap name="Working Room D - WiFi 2 - 5G" security=\
    default ssid=Skynet
add channel="channel 11 - 2.4Ghz" country=slovenia datapath=datapath \
    installation=indoor mode=ap name="Living Room - WiFi 1 - 2G" security=\
    default ssid=Skynet
add channel="channel 40 - 5Ghz (20 Mhz)" country=slovenia datapath=datapath \
    installation=indoor mode=ap name="Living Room - WiFi 2 - 5G" security=\
    default ssid=Skynet
add name=WAN
add name=LAN
add name=dhcp ranges=192.168.10.2-192.168.10.254
add name=dhcp_pool1 ranges=192.168.10.2-192.168.10.254
add name=vpn ranges=192.168.89.2-192.168.89.255
add address-pool=dhcp_pool1 disabled=no interface=bridge name=DHCP
/ppp profile
set *FFFFFFFE local-address=192.168.89.1 remote-address=vpn
/queue simple
add disabled=yes max-limit=768k/768k name=Gialt target=\
    "ether23 - Gialt,ether23 - Gialt"
add disabled=yes max-limit=768k/768k name=Elias target=\
    "ether17 - Elias,ether17 - Elias"
add disabled=yes dst="ether1 - OLD Modem" name=Test
/caps-man manager
set ca-certificate=auto certificate=auto enabled=yes
/caps-man provisioning
add action=create-dynamic-enabled master-configuration=\
    "Working Room M - WiFi 1 - 2G" name-format=identity radio-mac=\
    B8:69:F4:39:F8:9A
    "Working Room M - WiFi 2 - 5G" name-format=identity radio-mac=\
    B8:69:F4:39:F8:99
    "Working Room D - WiFi 1 - 2G" name-format=identity radio-mac=\
    64:D1:54:5E:25:EF
    "Working Room D - WiFi 2 - 5G" name-format=identity radio-mac=\
    64:D1:54:5E:25:EE
    "Living Room - WiFi 1 - 2G" name-format=identity radio-mac=\
    64:D1:54:5E:AD:BC
    "Living Room - WiFi 2 - 5G" name-format=identity radio-mac=\
    64:D1:54:5E:AD:BB
add bridge=bridge comment=defconf interface="ether3 - NAS 1"
add bridge=bridge comment=defconf interface="ether4 - NAS 2"
add bridge=bridge comment=defconf interface="ether5 - AP - Dominika"
add bridge=bridge comment=defconf interface="ether6 - AP - Marc"
add bridge=bridge comment=defconf interface="ether7 - AP - Living Room"
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=ether11
add bridge=bridge comment=defconf interface=ether12
add bridge=bridge comment=defconf interface=ether13
add bridge=bridge comment=defconf interface=ether14
add bridge=bridge comment=defconf interface=ether15
add bridge=bridge comment=defconf interface=ether16
add bridge=bridge comment=defconf interface="ether17 - Elias"
add bridge=bridge comment=defconf interface=ether18
add bridge=bridge comment=defconf interface=ether19
add bridge=bridge comment=defconf interface=ether20
add bridge=bridge comment=defconf interface=ether21
add bridge=bridge comment=defconf interface=ether22
add bridge=bridge comment=defconf interface="ether23 - Gialt"
add bridge=bridge comment=defconf interface=ether24
add bridge=bridge interface=sfp-sfpplus1
add bridge=bridge interface=sfp-sfpplus2
add bridge=bridge interface=dynamic
/interface detect-internet
set detect-interface-list=all
/interface l2tp-server server
set enabled=yes use-ipsec=yes
add interface="ether1 - OLD Modem" list=WAN
add interface=ether2 list=LAN
add interface="ether3 - NAS 1" list=LAN
add interface="ether4 - NAS 2" list=LAN
add interface="ether5 - AP - Dominika" list=LAN
add interface="ether6 - AP - Marc" list=LAN
add interface="ether7 - AP - Living Room" list=LAN
add interface=ether8 list=LAN
add interface="ether9 - Modem NEW" list=LAN
add interface=ether10 list=LAN
add interface=ether11 list=LAN
add interface=ether12 list=LAN
add interface=ether13 list=LAN
add interface=ether14 list=LAN
add interface=ether15 list=LAN
add interface=ether16 list=LAN
add interface="ether17 - Elias" list=LAN
add interface=ether18 list=LAN
add interface=ether19 list=LAN
add interface=ether20 list=LAN
add interface=ether21 list=LAN
add interface=ether22 list=LAN
add interface="ether23 - Gialt" list=LAN
add interface=ether24 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=sfp-sfpplus2 list=LAN
add interface=bridge list=LAN
/interface pptp-server server
set enabled=yes
/interface sstp-server server
set default-profile=default-encryption enabled=yes
add address=192.168.10.1/24 interface=bridge network=192.168.10.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add disabled=no interface="ether9 - Modem NEW"
/ip dhcp-relay
add dhcp-server=192.168.10.1 disabled=no interface="Working Room Dominika-1" \
    name=relay_1
add dhcp-server=192.168.10.1 disabled=no interface="Working Room Dominika-2" \
    name=relay_2
/ip dhcp-server lease
add address=192.168.10.6 client-id=1:0:11:32:e9:8b:c2 mac-address=\
    00:11:32:E9:8B:C2 server=DHCP
add address=192.168.10.5 client-id=1:0:11:32:e9:8b:c1 mac-address=\
    00:11:32:E9:8B:C1 server=DHCP
add address=192.168.10.99 client-id=1:28:d2:44:5b:e8:3 mac-address=\
    28:D2:44:5B:E8:03 server=DHCP
add address=192.168.10.2 client-id=1:b8:69:f4:39:f8:93 mac-address=\
    B8:69:F4:39:F8:93 server=DHCP
add address=192.168.10.10 client-id=1:b8:e8:56:41:65:4c mac-address=\
    B8:E8:56:41:65:4C server=DHCP
add address=192.168.10.4 client-id=1:64:d1:54:5e:25:e8 mac-address=\
    64:D1:54:5E:25:E8 server=DHCP
add address=192.168.10.3 client-id=1:64:d1:54:5e:ad:b5 mac-address=\
    64:D1:54:5E:AD:B5 server=DHCP
add address=192.168.10.42 client-id=1:5c:b9:1:5f:71:f3 mac-address=\
    5C:B9:01:5F:71:F3 server=DHCP
add address=192.168.10.13 client-id=1:94:b8:6d:98:6c:eb mac-address=\
    94:B8:6D:98:6C:EB server=DHCP
add address=192.168.10.43 client-id=1:a2:7b:e3:76:c:e2 mac-address=\
    A2:7B:E3:76:0C:E2 server=DHCP
add address=192.168.10.20 client-id=1:b4:2e:99:40:3a:80 mac-address=\
    B4:2E:99:40:3A:80 server=DHCP
add address=192.168.10.11 client-id=1:2e:f1:69:fe:5a:97 mac-address=\
    2E:F1:69:FE:5A:97 server=DHCP
add address=192.168.10.12 client-id=1:78:7e:61:7b:d0:d9 mac-address=\
    78:7E:61:7B:D0:D9 server=DHCP
add address=192.168.10.41 client-id=1:d4:d2:52:88:39:4d mac-address=\
    D4:D2:52:88:39:4D server=DHCP
add address=192.168.10.40 client-id=1:b4:a9:fc:17:a8:ab mac-address=\
    B4:A9:FC:17:A8:AB server=DHCP
add address=192.168.10.0/24 gateway=192.168.10.1 netmask=24
set allow-remote-requests=yes servers=84.255.209.79,84.255.210.79
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you nee\
    d this subnet before enable it" disabled=yes list=bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you \
    need this subnet before enable it" disabled=yes list=bogons
add address=192.168.0.0/16 comment="Private[RFC 1918] - CLASS C # Check if you\
    \_need this subnet before enable it" disabled=yes list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" list=\
    bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=bogons
add address=224.0.0.0/4 comment=\
    "MC, Class D, IANA # Check if you need this subnet before enable it" \
add address=192.168.10.0/24 list=support
add action=fasttrack-connection chain=forward connection-state=\
    established,related
add action=add-src-to-address-list address-list=Syn_Flooder \
    address-list-timeout=30m chain=input comment=\
    "Add Syn Flood IP to the list" connection-limit=30,32 protocol=tcp \
    tcp-flags=syn
add action=accept chain=input comment="allow IPsec NAT" dst-port=4500 \
    protocol=udp
add action=accept chain=input comment="allow IKE" dst-port=500 protocol=udp
add action=accept chain=input comment="allow l2tp" dst-port=1701 protocol=udp
add action=accept chain=input comment="allow pptp" dst-port=1723 protocol=tcp
add action=accept chain=input comment="allow sstp" dst-port=443 protocol=tcp
add action=drop chain=input comment="Drop to syn flood list" \
    src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner \
    address-list-timeout=1w chain=input comment="Port Scanner Detect" \
    protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" \
    src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" jump-target=\
    ICMP protocol=icmp
add action=drop chain=input comment="Block all access to the winbox - except t\
    o support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUP\
    PORT ADDRESS LIST" disabled=yes dst-port=8291 protocol=tcp \
    src-address-list=!support
add action=jump chain=forward comment="Jump for icmp forward flow" \
    jump-target=ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=\
    bogons
add action=add-src-to-address-list address-list=spammers \
    address-list-timeout=3h chain=forward comment=\
    "Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=\
    25,587 limit=30/1m,0 protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 \
    protocol=tcp src-address-list=spammers
add action=accept chain=input comment="Accept DNS - UDP" port=53 protocol=udp
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input comment="Accept to established connections" \
    connection-state=established
add action=accept chain=input comment="Accept to related connections" \
    connection-state=related
add action=accept chain=input comment="Full access to SUPPORT address list" \
    src-address-list=support
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP \
    protocol=icmp
add action=drop chain=input comment="Drop anything else! # DO NOT ENABLE THIS \
    RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED" disabled=yes
add action=accept chain=ICMP comment=\
    "Echo request - Avoiding Ping Flood, adjust the limit as needed" \
    icmp-options=8:0 limit=2,5 protocol=icmp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=\
    icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 \
    protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=\
    3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" protocol=icmp
add action=accept chain=forward connection-state=established,related
add action=masquerade chain=srcnat comment="masq. vpn traffic" src-address=\
    192.168.89.0/24
add disabled=yes distance=1 gateway=192.168.88.1
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www address=192.168.10.0/24
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/ppp secret
add name=vpn
/queue simple
add disabled=yes max-limit=768k/768k name=Dominika target=*62,*63
/system clock
set time-zone-name=Europe/Ljubljana
/system identity
set name="Main Router"
/system routerboard settings
set boot-os=router-os
/system swos
set allow-from-ports=p2 identity="MikroTik Switch"
Users browsing this forum: Bing [Bot], herger and 46 guests
