muk
2 WAN Auto Failover
Fri Feb 03, 2023 4:05 pm
Hi
Dear Team
Hope you are fine
I have RB951G-2HnD v7.7
i want to make auto failover links in router board. when the 1st link is down physically then automatically shifted to 2nd link but, when link is down logically then link is not shifted to another link.
how can i resolve this issue..??
thn80
Re: 2 WAN Auto Failover
Fri Feb 03, 2023 4:08 pm
What exactly have you configured so far?
muk
Fri Feb 03, 2023 4:33 pm
RouterOS 7.7
model = RB951G-2HnD
add name=bridge1_LAN
set [ find default-name=ether1 ] name=WAN1_ether1
set [ find default-name=ether2 ] name=WAN2_ether2
set [ find default-name=ether3 ] name=WAN3_ether3
set [ find default-name=ether4 ] name=ether4_LAN
set [ find default-name=ether5 ] name=ether5_LAN
add name=dhcp_pool1 ranges=77.77.77.51-77.77.77.254
add address-pool=dhcp_pool1 interface=bridge1_LAN lease-time=1h name=dhcp1
/routing table
add disabled=no fib name=WAN2_route
add disabled=no fib name=WAN3_route
add disabled=no fib name=WAN1_route
add disabled=no fib name=to_WAN1
add disabled=no fib name=to_WAN2
add bridge=bridge1_LAN interface=ether4_LAN
add bridge=bridge1_LAN interface=wlan1
add bridge=bridge1_LAN interface=wlan2
add bridge=bridge1_LAN interface=ether5_LAN
add address=192.168.18.151/24 interface=WAN2_ether2 network=192.168.18.0
add address=192.168.100.151/24 interface=WAN1_ether1 network=192.168.100.0
add address=77.77.77.1/24 interface=bridge1_LAN network=77.77.77.0
add address=192.168.50.151/24 interface=WAN3_ether3 network=192.168.50.0
add address=77.77.77.0/24 gateway=77.77.77.1
set allow-remote-requests=yes servers=8.8.8.8,4.4.2.2
/ip firewall mangle
add action=mark-connection chain=output connection-mark=no-mark \
    connection-state=new new-connection-mark=WAN1_Conn out-interface=\
    WAN1_ether1 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN1_Conn \
    new-routing-mark=to_WAN1 out-interface=WAN1_ether1 passthrough=yes
    connection-state=new new-connection-mark=WAN2_Conn out-interface=\
    WAN2_ether2 passthrough=yes
add action=mark-routing chain=output connection-mark=WAN2_Conn \
    new-routing-mark=to_WAN2 out-interface=WAN2_ether2 passthrough=yes
add action=masquerade chain=srcnat src-address=77.77.77.0/24
add action=masquerade chain=srcnat out-interface=WAN1_ether1
add action=masquerade chain=srcnat out-interface=WAN2_ether2
add action=masquerade chain=srcnat out-interface=WAN3_ether3
add check-gateway=ping disabled=no distance=3 dst-address=0.0.0.0/0 gateway=\
    192.168.100.1 pref-src="" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
add check-gateway=ping disabled=no distance=2 dst-address=0.0.0.0/0 gateway=\
    192.168.18.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=\
    no target-scope=10
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    192.168.18.1 pref-src="" routing-table=WAN2_route scope=30 \
add disabled=yes distance=1 dst-address=8.8.8.8/32 gateway=192.168.100.1 \
    pref-src="" routing-table=main scope=10 suppress-hw-offload=no \
    target-scope=10
add disabled=yes distance=1 dst-address=4.4.2.2/32 gateway=192.168.18.1 \
    target-scope=10
    192.168.50.1 pref-src="" routing-table=main scope=30 suppress-hw-offload=\
    no target-scope=10
    192.168.50.1 pref-src="" routing-table=WAN3_route scope=30 \
add check-gateway=ping disabled=yes distance=1 dst-address=0.0.0.0/0 gateway=\
    8.8.8.8 pref-src="" routing-table=to_WAN1 scope=30 suppress-hw-offload=no \
    target-scope=11
add check-gateway=ping disabled=yes distance=2 dst-address=0.0.0.0/0 gateway=\
    4.4.2.2 pref-src="" routing-table=to_WAN1 scope=30 suppress-hw-offload=no \
    target-scope=11
    4.4.2.2 pref-src="" routing-table=to_WAN2 scope=30 suppress-hw-offload=no \
    target-scope=11
    8.8.8.8 pref-src="" routing-table=to_WAN2 scope=30 suppress-hw-offload=no \
    target-scope=11
Users browsing this forum: Amazon [Bot] and 50 guests
