Gepp87
How to block traffic from one IP to the local network
Fri Feb 03, 2023 9:38 pm
I want to block the access of one local IP (192.168.1.100) to the local network (192.168.1.0/24), but so that this IP can be connected from the local network, e.g. via RDP. How should the firewall be set then?
anav
Re: How to block traffic from one IP to the local network
Sun Feb 05, 2023 11:49 pm
Depends on the rest of the config.
/export file=anynameyouwish (minus router serial number and any public WANIP information etc. )
BartoszP
Sun Feb 05, 2023 11:55 pm
If traffic from 192.168.1.100 goes via router then you can block it so you have connect this particular device to any port which belongs to 192.168.1.0/24 subnet/bridge. If devices use any external switch they bypass router talking directly and router is involved only when thet talk to WAN.
Gepp87
Tue Feb 07, 2023 9:43 am
Ok, device use external switch... I have to look for another solution
Users browsing this forum: No registered users and 52 guests
