fakeusername2022
Feature Request: OpenVPN with UDP and TCP (both)
Fri Feb 03, 2023 10:16 pm
Would be great to be able to have the builtin OpenVPN with both TCP and UDP enabled. Currently it is just limited to one protocol and port while theorically RouterOS can allow both being enabled on different ports.
It is usefull for The Internet Enemy countries VPN access and also Road Warrior VPN access from different unknown environments each with its own limitations.
Would appreciate it if you clould kindly consider adding the feature.
Thanks.
pe1chl
Re: Feature Request: OpenVPN with UDP and TCP (both)
Fri Feb 03, 2023 10:55 pm
Official OpenVPN does not support that either...
fakeusername2022
Sun Feb 05, 2023 2:55 pm
I think it is possible: https://forums.openvpn.net/viewtopic.php?t=10473
pe1chl
Sun Feb 05, 2023 3:02 pm
That article explains it is NOT possible. There is a workaround: run two different servers.
anav
Sun Feb 05, 2023 4:08 pm
I think the OP also denies man landed on the moon and the US was behind the twin towers terrorism.
fakeusername2022
Sun Feb 05, 2023 8:02 pm
I have a mikrotik router with N IP addresses. Why shouldnt I be able to assign one OVPN server instance to each IP address?!
Same applies to SSTP server configuration...
pe1chl
Sun Feb 05, 2023 8:12 pm
Yeah, with MikroTik there is the problem that in one router you can run only one OpenVPN server. You would need a second router or some solution using container.
aleab
Sun Feb 05, 2023 8:53 pm
+1 for me.
for some installations i used "port forwarding" to use more TCP port.
but is useful have more OVPN server (as I did in the past with pfsense)
thank you
ech1965
Sun Feb 05, 2023 11:57 pm
+1 for multiple servers ( whatever UDP/TCP but of course different ports ) for me,
On my opnsense installs, I often create mutliple servers with different sets of allowed inside network ( sysadmin vpn with full access, user server with restricted, guest server with even more restricted)
fakeusername2022
Mon Feb 06, 2023 7:27 pm
+1 for me.
thank you
Multiple TCP or UDP ports might be possible with firewall nat but it is just limited to either TCP or UDP...
Users browsing this forum: No registered users and 14 guests
