hci
Long time Member
Long time Member
Wireguard Config File
Sat Feb 04, 2023 1:22 am
The wireguard app asks if you would like to create a tunnel from a file or QR code. Any directions on making these things?
Larsa
Re: Wireguard Config File
Sat Feb 04, 2023 1:32 am
Which Wireguard app and where did you get the QR code from?
hci
Long time Member
Long time Member
Sat Feb 04, 2023 2:06 am
The iPhone app asks for config file or QR code. Also manual option. Windows app same except no QR code option.
chechito
Sat Feb 04, 2023 2:21 am
first google search result of : wireguard qr code generator
https://www.wireguardconfig.com/qrcode
Larsa
Sat Feb 04, 2023 2:31 am
If you mean like the attched picture then it all depends on you've allready installed you own or use an existing wireguard endpoint (server) that may supply you with all the details that the mobile client is asking for, either throug the a QR code (which the server must provide if available), using a preconfigured Wireguard config file or manually be entering all the info by hand.
Ref: (google "wireguard iphone app configuration")
https://www.ivpn.net/setup/ios-wireguard/
https://blacklab.net/algo-vpn-installin ... ac-iphone/
https://wireguard.how/client/ios/
https://mullvad.net/en/help/wireguard-ios/
anav
Sat Feb 04, 2023 3:53 am
I create from scratch but that is to an MT device acting as server for the connection.
optio
Long time Member
Long time Member
Sat Feb 04, 2023 7:52 pm
In iOS app you can create from scratch in app form, eg:
If you want to create config from QR, create config with wireguard config generator: https://www.wireguardconfig.com/, paste config text into some QR code generator, eg. https://goqr.me/ and scan generated QR from app.
optio
Long time Member
Long time Member
Sat Feb 04, 2023 8:29 pm
Bump, https://www.wireguardconfig.com actually generates QR code for configuration so you don't need to use extra QR code generator...
bedazzled
Sun Jul 02, 2023 11:39 am
https://youtu.be/9y_ioXrkjMg
own3r1138
Long time Member
Long time Member
Tue Jul 04, 2023 8:33 pm
I rather generate the QR code locally.
crash fix
sebus46
Fri Mar 29, 2024 12:12 am
Github specific repo is gone, but the plugin from NPP++ installs fine
Other repo exists here https://github.com/vladk1973/npp-plugins-x64
Users browsing this forum: bcmdevtl, Qanj72, raiser, slimmerwifi, Valerio5000 and 163 guests
