johnt107
VPN client runs but route says unreachable
Sun Feb 05, 2023 2:06 pm
I'm using a Hex S with Router OS 6.47.9
My VPN client connection has been working fine until recently. I've noticed that the machine I want to use the VPN no longer goes through the VPN.
I have set up a VPN interface to direct this one machine on my lan to the VPN. In the interface menu it says the VPN is connected and running.
I see in the IP/Routes menu it says the the VPN is unreachable.
What might cause this?
My internet physical connection did change recently, it is still PPOE, only the physical cable from the street and IP address changed.
What configuration items should I look at that would cause the "unreachable" status in the IP/Routes menu?
amirmahdi81
Re: VPN client runs but route says unreachable
Sun Mar 10, 2024 4:35 pm
Hi
did you figure out the problem?
Users browsing this forum: Bing [Bot], Fi011, iDaemon and 217 guests
