Hi Forum
I've been the happy user of a CSS326-24G-2S+RM for some time. Now when I try and login to manage the switch, it tells me wrong password.
It seems I've forgotten the username or password.
I've tried and follow other posts and guides to reset to factory default.
But nothing that is noted in the guides works. No matter what I do and how long or short i keep the reset switch pressed, it boots to the configuration and IP that I originaly set.
It seems, when i press the reset button, the switch boots very quickly and does not go to default 192.168.88.1 and admin user.
What can be done to reset the switch completely?
Should I go the Netinstaller way and upload a new firmware to the device?
If so, where do I get the correct firmware?
