adam23450
Problem with IPSEc Site-to-Site VPN
Sun Feb 05, 2023 8:16 pm
Hi, I've been looking for an answer for a long time how to connect 2 points using a VPN. I found that I can do this using IPSEC Site-to-Site. I have mikrotik on one side and debian system with strong swan software on the other. When I connect mikrotik and strong swan, the connection is established, but I cannot ping linux from other networks than the one indicated. How to make all networks visible and reachable from all networks in debian 11?
anav
Re: Problem with IPSEc Site-to-Site VPN
Mon Feb 06, 2023 7:01 pm
I can help using wireguard, but not ipsec......... suggest you try it.
Users browsing this forum: GODEEPAS, Google [Bot], mstanciu and 81 guests
