zibensdraugs
Port forwarding with password (using reverse proxy)
Mon Feb 06, 2023 4:38 am
Hello, I have network device that I want to access from public internet, but it is not password protected, so I can not just port forward to it, otherwise anyone will be able to coctrol it.
I understand to make password authentification to this device I need to create reverse proxy (like NGINX).
Is it possible to setup reverse proxy inside Mikrotik router or I need to have PC to do that?
normis
Re: Port forwarding with password (using reverse proxy)
Mon Feb 06, 2023 8:23 am
No, you can't.
You can set up a VPN server in your router and only access the service through the VPN.
Or maybe you could do this: https://youtu.be/BbDnBxlBTdY
anav
Mon Feb 06, 2023 3:55 pm
YES, YOU CAN DO THIS USING ZERO TRUST TUNNEL BY CLOUDFLARE.
IT IS THE SAFEWAY TO SETUP A SERVER AND NOT EXPOSE YOUR WANIP.
HOWEVER MIKROTIK ONLY OFFERS THIS in a BACKHANDED WAY for ARM DEVICES (slap in the face for other device owners BOOOOO!!! ) and FURTHER YOU HAVE TO LEARN CONTAINERS which has its own security risks and is not TRIVIAL for a beginner.
WAKEUP NORMUNDS!!!!! Put zero trust cloudflare tunnel in a package option for ALL DEVICES.
zibensdraugs
Tue Feb 14, 2023 9:57 pm
Hi, I looked up about this Cloudflare Zero Trust tunnel, but I realised that this docker is available only for ARM64 not just ARM, so it would go only for the newest mikrotik routers...
https://hub.docker.com/r/pihole/pihole/tags
So if somehow it is possible with ARM processors, let me know, I will try also other dockers...
massinia
Tue Feb 14, 2023 10:04 pm
Look at Zerotier, there is a package for your router.
Much easier to configure…
massinia
Re: Inoltro porta con password (utilizzando proxy inverso)
Tue Feb 14, 2023 10:12 pm
Zerotier would be also really helpful
Users browsing this forum: No registered users and 14 guests
