texmeshtexas
Find address list to which an IP belongs
Mon Feb 06, 2023 6:19 am
In winbox if I filter in /ip/firewall/address-list for and address that is part of a subnet, it displays properly.
Example: filter for 100.72.58.74
there is an address list that contains 100.64.0.0/10 so the list and subnet to which that IP is part of is displayed.
However, in a script I'm trying to do the same with
:put [/ip/firewall/address-list print where address=100.72.58.74]
or
:put [/ip/firewall/address-list get value-name=list [find address=100.72.58.74]]
both return nothing.
Is there a way to replicate what can be done in winbox?
texmeshtexas
Re: Find address list to which an IP belongs
Mon Feb 06, 2023 6:20 am
I have seen this post viewtopic.php?p=287021&hilit=find+addre ... gs#p287021
and it does not seem to work either.
rextended
Mon Feb 06, 2023 1:14 pm
You must not use "=" if the IP is not exactly the address list entry...
Obviously 1.2.3.4 is not = to 1.2.3.0/24
Is easy, you must search oe address that is in the pool or identical to the single address...:
/ip firewall address-list print where ( (100.72.58.74 in address) or (100.72.58.74=address) )
For use on scripting:
    :local addr  100.72.58.74
    :local nlist ({})
    :foreach index in=[find where ( ($addr in address) or ($addr=address) )] do={
        :set nlist ($nlist,[get $index list])
    :put "The address $addr is on lists $[:tostr $nlist]"
texmeshtexas
Mon Feb 06, 2023 3:44 pm
Thank you Rextended, that works perfectly! I was not aware of the "in" operator.
rextended
Mon Feb 06, 2023 4:33 pm
Users browsing this forum: No registered users and 65 guests
