e3acf43dcd074d7884d
Initial setup
Mon Feb 06, 2023 11:50 am
Hi
Bought a new MikroTik hAP ac2 Dual Band 5 Port and am struggling to set it up.
The packaged instructions and the wiki (https://help.mikrotik.com/docs/display/ ... figuration) refer to HTTP into 192.168.88.1.
That IP isn't working. I can see and connect to the "MikroTik" SSID.
Using WinBox as detailed in the wiki (find neighbours) I can see the router at 192.168.101.1 ... but that IP doesn't respond to HTTP/S requests either.
WinBox can't connect to the router either using the default credentials (admin/blank pwd).
What should I do here? It's almost like the device came with some non-default config, but it was sealed and new as far as I know.
normis
Re: Initial setup
Mon Feb 06, 2023 11:55 am
Where did you buy it? If it came from your ISP, they sometimes pre-configure it some other way. Then you must ask the seller / installer
e3acf43dcd074d7884d
Re: Initial setup
Mon Feb 06, 2023 11:58 am
No, it's not from the ISP. A generic large online retailer, think Amazon but a local competitor.
Edit: I checked the listing again and it's a third party one - some random local tech supplier. I'll try and contact them but I'm not super hopeful.
Unfortunately I waited too long and the "no questions asked" return period had passed.
erlinden
Re: Initial setup
Mon Feb 06, 2023 12:45 pm
e3acf43dcd074d7884d
Re: Initial setup
Mon Feb 06, 2023 1:57 pm
Thanks for that link, I will try it out. Is that model a RouterBOARD device?
e3acf43dcd074d7884d
Re: Initial setup
Thu Feb 16, 2023 10:50 am
Just to close the loop: the factory reset worked. Thanks for the assistance.
anav
Re: Initial setup
Thu Feb 16, 2023 2:32 pm
You didnt get a new unit, it had been used prior.
Users browsing this forum: No registered users and 12 guests
