lanhampr
Wrong log message order for DHCP messages.
Mon Feb 06, 2023 5:32 pm
I am running 7.7 and in my winbox log the DHCP assigned is logging before the deassigned message.
I see on another MT running 7.7 the order is correct. Hmm.
erlinden
Re: Wrong log message order for DHCP messages.
Mon Feb 06, 2023 5:57 pm
That wouldn't make sense...can you share /log print ?
lanhampr
Mon Feb 06, 2023 6:12 pm
The log printed from terminal is correct:
09:08:24 dhcp,info NOC3-CGNAT deassigned 100.64.4.227 for 76:56:9F:BB:0C:93 Z6250CC
09:08:24 dhcp,info NOC3-CGNAT assigned 100.64.4.227 for 76:56:9F:BB:0C:93 Z6250CC
but in Winbox log it's reversed.
erlinden
Mon Feb 06, 2023 6:16 pm
Strange...haven't seen this behaviour. The log isn't ordered on the #column...that would help :o
lanhampr
Tue Feb 07, 2023 2:20 am
I order by time.
erlinden
Tue Feb 07, 2023 10:03 am
I order by time.
Ok, that is your problem...
lanhampr
Tue Feb 07, 2023 7:33 pm
I guess I don't get that. I want to see log messages in chronological order. A release should show before an assign based on time.
mkx
Tue Feb 07, 2023 8:44 pm
The log entries probably followed each other with short time difference, small enough to have timestamp (stored with a second resolution) the same. If you'd let winbox show logs without sorting, you'd get them in order as they were recorded. Since you enabled sorting, you get it ... but entries with same timestamp can be sorted randomly.
Users browsing this forum: amazen, Bing [Bot], hofi76, smirgo, tigro11 and 71 guests
