Hermanis
Newbie question| Make RDP more secure
Mon Feb 06, 2023 6:51 pm
Hello folks.
I would like to setup avery basic RDP (windows remote desktop) security.
I need to connect to the remote PC located on the other side of my city using windows RDP.
No need for complex stuff like encryption, vpn etc...the simplier the better as there is nothing valuable on this PC.
Perhaps allowing to connect frome some specific IP address (or address range) would be enough.
By reading a manuals I finally succeeded with simple port forwarding (see picture attached) and feel proud of it :)
But none of the manuals were easy enough to guide me to some "ip whitelist" solution.
Any help would be appreciated.
Thanks!
anav
Re: Newbie question| Make RDP more secure
Tue Feb 07, 2023 6:55 pm
Your requirements are not clear and it appears you are trying to stuff a round peg into a square hole syndrome.
In other words, you assumed a solution without discussing what it is the users actually need.//////////////
arnoldmikro
Re: Newbie question| Make RDP more secure  [SOLVED]
Tue Feb 07, 2023 8:48 pm
Try this
it uses address lists to restrict connections
add action=accept chain=forward dst-address=192.168.3.4 dst-port=3389 \
in-interface=ether1-gateway protocol=tcp src-address-list=rdp
add action=dst-nat chain=dstnat dst-port=3389 in-interface=ether1-gateway \
protocol=tcp src-address-list=rdp to-addresses=192.168.3.4 to-ports=3389
/ip firewall address-list
add address=YOUR REMOTE WAN ADDRESS comment=home list=rdp
Hermanis
Sat Feb 11, 2023 11:18 am
To: arnoldmikro
Thanks a lot. Your scripts worked exactly like I wanted. Now I have RDP access to the remote pc only from fixed IPs.
To: anav
Each time I have to do some adjustments to my Mikrotiks I feel either dumb or lazy.
Imho Ros is just so user-unfriendly for the user who doesn't want to invest a lot of time into setup, but wants reliable hardware for reasonable price.
Sometimes I regret I've bought those two devices..and this makes me feel sorry for local manufacturer (yes, I live here :))
Thanks a lot guys!
ConradPino
Sat Feb 11, 2023 7:11 pm
Agreed, RouterOS is not consumer friendly in the same way as ASUS, D-Link, Netgear, or TP-Link consumer products.
RouterOS is enterprise function at value price. Arista, Cisco, Juniper, etc. at enterprise level are skill development challenges as well.
Users browsing this forum: No registered users and 109 guests
