Thu Feb 09, 2023 2:52 am
Without more info, lots of issues could be causing this...
- firmware/software version (v7 still has issues)
- interfaces not set properly
- interference from neighbouring devices on 2.4 GHz
- Distance and walls (worse on 5 GHz)
- Device not behaving as expected with the MikroTik radio
- Bad configuration
I've seen reports of 600-800 Mbps on these new AX devices, so 20 is not normal. BTW, user bpwl has posted lots of great advice over the years on how to troubleshoot/tweak wireless issues if you do a search...
