zywczak
Ipsec VPN to Azure Point-to-site
Mon Feb 06, 2023 11:25 pm
I'm trying to establish p2s connection to azure, based on IKEv2, using certificates for authentication.
I'm using the following configuration:
/ip ipsec mode-config
add name=azure responder=no
/ip ipsec policy group
add name=azure
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=aes-256,aes-128 lifetime=7h30m name=azure
/ip ipsec peer
add address=azuregateway-******.vpn.azure.com exchange-mode=ike2 name=azure profile=azure
/ip ipsec proposal
add auth-algorithms=sha256,sha1 enc-algorithms=aes-256-cbc,aes-128-cbc lifetime=8h name=azure
/ip ipsec identity
add auth-method=digital-signature certificate="{client_certificate}" mode-config=azure peer=azure policy-template-group=azure remote-certificate="{gateway_certificate}"
/ip ipsec policy
add dst-address=0.0.0.0/0 group=azure proposal=azure src-address=0.0.0.0/0 template=yes
Unfortunately I'm getting AUTHENTICATION FAILED messaged from VPN:
22:19:13 ipsec,info new ike2 SA (I): azure {localIP}[4500]-{gatewayIp}[4500] spi:4b064ff5edd37f3e:358930ac1e611259
22:19:13 ipsec,error got fatal error: AUTHENTICATION_FAILED
22:19:13 ipsec,info killing ike2 SA: azure {localIP}[4500]-{gatewayIp}[4500] spi:4b064ff5edd37f3e:358930ac1e611259
Can you please help me, what is wrong with this setup.
Gateway certificate I got from Azure config,
Client certificate was generated based on this approach: https://learn.microsoft.com/en-us/azure ... site-linux
MickeyT
Re: Ipsec VPN to Azure Point-to-site
Wed Feb 08, 2023 9:26 am
I've never used certificates with Azure VPN and, based on details here, it looks like MS only support using pre-shared keys.
Microsoft also provide a site-to-site VPN tutorial that you might want to read through (If you haven't already).
Backups are your friend. Always make a backup!
/system backup save encryption=aes-sha256 name=MyBackup
zywczak
Mon Feb 27, 2023 2:37 pm
Yes, but why?
It should be possible, after all there is event a part in mikrotik's manual about setting up this kind of connection: https://wiki.mikrotik.com/wiki/Manual:I ... figuration
On the other hand, I don't see reason why Azure VPN should prevent from this kind of connection, should this be similar to configration in linux or macos. I was hoping that proper setup of myId (certificate's subject) and remoteId (Gateway FQDN) as described here https://learn.microsoft.com/en-us/azure ... -osx-ikev2 would help, but it didn't.
Maybe I still have something wrong here:
MickeyT
Wed Mar 01, 2023 11:55 am
Yes, but why?
You would need to ask Microsoft about that. Just because MikroTik support the use of certificates doesn't mean that others will.
woland
Wed Mar 01, 2023 12:26 pm
MS supports certificate auth for p2s connections and the docs are great: https://learn.microsoft.com/en-us/azur ... cert-linux
OP means p2s and not for s2s.
Anyway unfortunately I don´t see the reason why OPs config would not work. Probably something about the certificates and there is also a nice trap here:
The Basic SKU Azure VPNGW does not support P2S IKE2!!!
https://learn.microsoft.com/en-us/azure ... site-about
Of course thats a bit off topic here...
Users browsing this forum: Amazon [Bot], Bing [Bot], ianjay06 and 99 guests
