Zoolander06
Passive IPSec tunnel issue
Tue Feb 07, 2023 5:38 pm
Hello folks,
I have a weird issue with an IKEv2 tunnel set as passive.
The originator has no problem to establish the tunnel, and everything seems good, but there is absolutely no trafic.
The weird part is that if I ping a distant device just once, everything start to work normally.
I don't understand why, and it's quite unconvenient, so, does anyone have any idea about what I missed ?
Thanks,
Joris
Zoolander06
Re: Passive IPSec tunnel issue
Fri Feb 24, 2023 6:21 pm
Nobody has any idea ?
I have now a second IKEv2 tunnel with the exact same issue...
Does anybody knows how I can trigger a ping when the tunnel goes up, it would be a workaround at least...
Thanks,
Joris
Larsa
Fri Feb 24, 2023 6:27 pm
If you want help from people on this user forum, please post your config and a brief description of the network topology. You may also mail Mikrotik customer support.
Zoolander06
Fri Feb 24, 2023 6:52 pm
The topology is pretty standard, I have 2 WAN interfaces and one LAN.
First WAN is PPPoE, and is used for the problematic tunnel.
Second WAN is IP, and is used as a backup, but not for this tunnel.
There is multiple addresses on the LAN interface because the customer previously had multiple gateways, and it's what I usually do to avoid changes on other devices (most of the time, I don't have access to those).
There is also gre tunnels to another site, and a roadwarrior L2TP/IPSEC VPN.
Nothing really fancy or unusual for me...
Of course, here is my config :
add admin-mac=2C:C8:1B:EE:30:FB arp=proxy-arp auto-mac=no comment=defconf \
    name=bridge
/interface gre
add local-address=eee.fff.ggg.hhh name=gre-tunnel1 remote-address=\
    iii.jjj.kkk.lll
add allow-fast-path=no local-address=10.0.1.2 name=gre-tunnel2 \
    remote-address=mmm.nnn.ooo.ppp
add comment=defconf name=WAN
add comment=defconf name=LAN
/ip dhcp-server option
add code=66 name=TFTP_UNYC value="'https://xxxxxxxxxxxxxxxxx'"
/ip ipsec policy group
add name=MISTRAL
/ip ipsec profile
add dh-group=ecp256 dpd-interval=disable-dpd enc-algorithm=aes-256 \
    hash-algorithm=sha256 lifetime=1h name=mistral
/ip ipsec peer
add address=aaa.bbb.ccc.ddd/32 exchange-mode=ike2 local-address=eee.fff.ggg.hhh \
    name=MISTRAL passive=yes profile=mistral send-initial-contact=no
/ip ipsec proposal
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=15m name=\
    mistral pfs-group=modp2048
add name=default-dhcp ranges=192.168.7.101-192.168.7.150
add name=dhcp-VPN ranges=192.168.7.151-192.168.7.155
add address-pool=default-dhcp interface=bridge name=defconf
/ppp profile
add change-tcp-mss=yes name=PPPoE only-one=yes use-compression=no \
    use-encryption=no use-mpls=no use-upnp=yes
add change-tcp-mss=yes interface-list=LAN local-address=192.168.7.254 name=\
    VPN only-one=yes remote-address=dhcp-VPN
/interface pppoe-client
add allow=pap,chap disabled=no interface=ether1 name=vdsl-ether1 profile=\
    PPPoE user=ip22120998541@srvc
/routing table
add disabled=no fib name=WAN1
add disabled=no fib name=WAN2
/snmp community
set [ find default=yes ] name=Monitoring write-access=yes
add bridge=bridge comment=defconf ingress-filtering=no interface=ether3
add bridge=bridge comment=defconf ingress-filtering=no interface=ether4
add bridge=bridge comment=defconf ingress-filtering=no interface=ether5
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan1
add bridge=bridge comment=defconf ingress-filtering=no interface=wlan2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface l2tp-server server
set authentication=mschap1,mschap2 enabled=yes use-ipsec=required
add comment=defconf interface=vdsl-ether1 list=WAN
add interface=ether2 list=WAN
add interface=gre-tunnel1 list=LAN
add interface=gre-tunnel2 list=LAN
/interface ovpn-server server
set auth=sha1,md5
    192.168.88.0
add address=10.0.1.2/24 comment=VDSL interface=ether2 network=10.0.1.0
add address=192.168.7.254/24 interface=bridge network=192.168.7.0
add address=172.16.0.2/30 interface=gre-tunnel1 network=172.16.0.0
add address=172.16.0.6/30 interface=gre-tunnel2 network=172.16.0.4
add address=192.168.7.252/24 interface=bridge network=192.168.7.0
add address=192.168.0.254/24 interface=bridge network=192.168.0.0
add address=192.168.117.252/24 interface=bridge network=192.168.117.0
add address=192.168.7.0/24 dhcp-option=TFTP_UNYC gateway=192.168.7.254
set allow-remote-requests=yes servers=8.8.8.8,1.1.1.1,8.8.4.4
/ip dns static
/ip firewall address-list
add address=85.14.167.193 list=Unyc
add address=85.14.167.234 list=Unyc
    established,related,untracked
add action=accept chain=input dst-port=500,1701,4500 in-interface-list=WAN \
    protocol=udp
add action=accept chain=input in-interface-list=WAN protocol=gre
    invalid
    "Accept Webfig https connections from WAN" dst-port=8443 \
    in-interface-list=WAN protocol=tcp
add action=accept chain=input comment="Accept SNMP conections from Unyc" \
    dst-port=161,162 in-interface-list=WAN protocol=udp src-address-list=Unyc
    in-interface-list=!LAN
    ipsec-policy=in,ipsec
    ipsec-policy=out,ipsec
    connection-state=invalid
/ip firewall mangle
add action=mark-connection chain=prerouting connection-mark=no-mark \
    connection-state=related,new,untracked in-interface-list=LAN \
    new-connection-mark=lan-cnx passthrough=yes
    connection-state=related,new,untracked in-interface=vdsl-ether1 \
    new-connection-mark=wan1-cnx passthrough=yes
    connection-state=related,new,untracked in-interface=ether2 \
    new-connection-mark=wan2-cnx passthrough=yes
add action=mark-routing chain=prerouting connection-mark=wan1-cnx \
    dst-address-type=!local new-routing-mark=WAN1 passthrough=yes
add action=mark-routing chain=output connection-mark=wan1-cnx \
add action=mark-routing chain=prerouting connection-mark=wan2-cnx \
    dst-address-type=!local new-routing-mark=WAN2 passthrough=yes
add action=mark-routing chain=output connection-mark=wan2-cnx \
add action=accept chain=srcnat dst-address=192.63.63.0/24 src-address=\
    192.168.117.0/24
add action=accept chain=srcnat dst-address=192.168.117.0/24 src-address=\
    192.63.63.0/24
/ip firewall service-port
set sip disabled=yes
/ip ipsec identity
add generate-policy=port-strict peer=MISTRAL policy-template-group=MISTRAL
/ip ipsec policy
add dst-address=192.63.63.0/24 group=MISTRAL proposal=mistral src-address=\
    192.168.117.0/24 template=yes
add disabled=no distance=2 dst-address=0.0.0.0/0 gateway=10.0.1.1 pref-src="" \
    routing-table=main suppress-hw-offload=no
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=vdsl-ether1 \
    pref-src="" routing-table=main suppress-hw-offload=no
    pref-src="" routing-table=WAN1 suppress-hw-offload=no
add blackhole disabled=no distance=2 dst-address=0.0.0.0/0 gateway="" \
    pref-src="" routing-table=WAN2 suppress-hw-offload=no
add check-gateway=ping disabled=no distance=1 dst-address=0.0.0.0/0 gateway=\
    10.0.1.1 routing-table=WAN2 suppress-hw-offload=no
add check-gateway=ping disabled=no distance=1 dst-address=192.168.5.0/24 \
    gateway=172.16.0.1 routing-table=main suppress-hw-offload=no
add check-gateway=ping disabled=no distance=2 dst-address=192.168.5.0/24 \
    gateway=172.16.0.5 routing-table=main suppress-hw-offload=no
add check-gateway=ping disabled=no distance=1 dst-address=mmm.nnn.ooo.ppp/32 \
    gateway=10.0.1.1 pref-src="" routing-table=main scope=30 \
    suppress-hw-offload=no target-scope=10
add disabled=no distance=1 dst-address=iii.jjj.kkk.lll/32 gateway=vdsl-ether1 \
/ip service
set www-ssl certificate=WebFig disabled=no port=8443
/ppp secret
add name=Vpn_Nomade_DSL profile=VPN service=l2tp
add name=Vpn_Nomade_DSL_2 profile=VPN service=l2tp
/snmp
set enabled=yes
/system clock
set time-zone-name=Europe/Paris
/system ntp client
set enabled=yes
/system ntp client servers
add address=fr.pool.ntp.org
Any help would be highly appreciated :)
Joris
Users browsing this forum: Bing [Bot] and 173 guests
