Argosy
Failover
Tue Feb 07, 2023 5:50 pm
Hello I have a very instable powerline connection in my bedroom and now I tough i could just use two powerline adapter as for failover reason.
But how could I configure that? I can't use Bound or could I? Bound over two develo powerline adapters? Really not sure here. The problem is eth1 never goes down just the connection is so terrible that I need to reboot the powerline. Any Idea here?
Anyway that's the config on my CAP device.
add fast-forward=no name=br-lan
set [ find default-name=ether1 ] speed=100Mbps
set [ find default-name=ether2 ] speed=100Mbps
/interface mesh
add name=Mesh
/interface lte apn
add authentication-types=wpa2-psk mode=dynamic-keys name=blabla supplicant-identity=""
add authentication-types=wpa2-psk mode=dynamic-keys name=blabla2 supplicant-identity=""
/interface wireless
set [ find default-name=wlan2 ] antenna-gain=0 band=5ghz-n/ac channel-width=20/40/80mhz-XXXX country=no_country_set disabled=no frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge name=wlan5 radio-name=blabla5000 security-profile=blabla skip-dfs-channels=all ssid=WLANPrivat station-roaming=enabled wps-mode=disabled
set [ find default-name=wlan1 ] antenna-gain=0 band=2ghz-g/n channel-width=20/40mhz-XX country=no_country_set disabled=no frequency=auto frequency-mode=manual-txpower installation=indoor mode=ap-bridge name=wlan24 radio-name=blabla2400 security-profile=blabla ssid=WLANPrivat station-roaming=enabled wps-mode=disabled
add disabled=no hide-ssid=yes keepalive-frames=disabled mac-address=76:4D:28:2E:A0:3D master-interface=wlan24 multicast-buffering=disabled name=wlan24_2 security-profile=blabla2 ssid=WLANIOT wds-cost-range=0 wds-default-cost=0 wps-mode=disabled
/routing bgp template
set default disabled=no output.network=bgp-networks
/routing ospf instance
add disabled=no name=default-v2
/routing ospf area
add disabled=yes instance=default-v2 name=backbone-v2
add bridge=br-lan ingress-filtering=no interface=ether1
add bridge=br-lan interface=wlan24
add bridge=br-lan interface=wlan5
add bridge=br-lan interface=wlan24_2
add bridge=br-lan interface=ether2
/ip settings
set max-neighbor-entries=8192
/ipv6 settings
/interface ovpn-server server
set auth=sha1,md5
/interface wireless cap
set bridge=br-lan certificate=request discovery-interfaces=br-lan interfaces=wlan24,wlan5
/ip dhcp-client
add interface=br-lan
/ip service
set telnet disabled=yes
set ftp disabled=yes
set api disabled=yes
set api-ssl disabled=yes
/system clock
set time-zone-name=Europe/Zurich
/system identity
set name=ac-og
/system leds settings
set all-leds-off=after-1min
/system ntp client
set enabled=yes
holvoetn
Re: Failover
Tue Feb 07, 2023 6:07 pm
If your current powerline is already instable, adding a second one to the same electrical wires, will only make things worse.
Do you really have no option to pull a normal ethernet cable ? Not even via outside ?
I also used powerline from living room (where modem is) towards my home office. I got around 150mb throughput, I think.
Until I got solar panels installed ... the harmonics practically KILLED the powerline throughput (ok, exagerating here but you get the idea :lol: )
So I pulled a normal CAT6 via office through the floor into the garage, via ceiling of garage into basement, back up to living room.
Internal network is humming at close to 1Gbps now.
Argosy
Re: Failover
Tue Feb 07, 2023 8:41 pm
I have about 6 Powerline. The problem is only in the 3floor and the second on the 3floor dosn't have the problem at the same time
Users browsing this forum: Bing [Bot], gdanov, sch and 133 guests
