yaig
New OpenVPN community client (version 2.6) cannot connect to Mikrotik OpenVPN server
Tue Feb 07, 2023 9:52 pm
OpenVPN client version 2.5.8 successfully connected, after updateing client to 2.6,
it cannot connect.
config on client:
client
dev tap
proto tcp-client
remote ********** 11948
resolv-retry infinite
nobind
persist-key
tls-client
ca *****.crt
cert ******.crt
key ******.key
verb 3
data-ciphers AES-256-CBC
auth-user-pass
Mikrotik router version: 7.7.
According to routers log:
unknown cipher alg or key size
What is the correct config file on the client?
nellson
Re: New OpenVPN community client (version 2.6) cannot connect to Mikrotik OpenVPN server
Thu Feb 09, 2023 11:53 am
I can confirm this, we have the same issue with the 2.6 openvpn clients. I will post here, if I find a solution.
aoakeley
Sun Feb 12, 2023 12:54 pm
Can also confirm this.
I have tried a few options to resolve it, but other than to use an earlier version of the OpenVPN Client I can't see a solution right now.
Have either of you created a ticket? if it is important to you I suggest you bring it to the attention if the development team by creating a ticket with Mikrotik.
ivn
Re: New OpenVPN community client (version 2.6) cannot connect to Mikrotik OpenVPN server  [SOLVED]
Sun Feb 12, 2023 10:24 pm
Try to add
data-ciphers-fallback AES-256-CBC
to your client config.
anav
Sun Feb 12, 2023 10:27 pm
use wireguard and join the 21st century/Third Millenium/Decade of 2020-2030.
aoakeley
Mon Feb 13, 2023 3:42 am
Try to add
Well bugger me... I am sure I tested that yesterday and it did not work.
But tested again now with 2.6 and it worked fine.
Andrew
yaig
Wed Feb 15, 2023 10:28 am
Try to add
Thanks for the great tip! It works with this setting!
certinet
Fri Feb 24, 2023 6:45 pm
In fact, in OpenVPN 2.6, CBC is deprecated. We need to change this but does Mikrotik support another one?
Nikolyo
Wed Mar 15, 2023 6:23 pm
I had the same problem in the following setup:
Server: Mikrotik Open VPN server (RouterOS 6.49.7)
Clienti: Windows OpenVPN 2.6.1
In the Mikrotik:
OpenVPN Server config disable the Auth = SHA1 algorithms (nothing shoud be selected for a Auth)
In the Open VPN Client:
#cipher AES-256-CBC
data-ciphers AES-256-GCM:AES-128-GCM:AES-256-CBC
#auth SHA1
Unfortunately all of the clients have to be upgraded to OpenVPN 2.6.1
I could get it to run simultaneously for Open VPN client 2.5 and 2.6
BR :)
likedi
Sat Mar 25, 2023 5:01 pm
In the Mikrotik:
#cipher AES-256-CBC
#auth SHA1
BR :)
THIS is the answer. Thanks!
zvekyf
Thu Mar 30, 2023 10:04 pm
Server: Mikrotik Open VPN server (RouterOS 7.8 )
Clienti: Windows OpenVPN 2.6.2
If I set next it still connect with AES-256-CBC and without auth part I get error [unsupported auth digest]
auth SHA512
But if I set next connection is working.
cipher AES-256-GCM
disable-dco
Looks like data-ciphers parameter is ignored or something.
Users browsing this forum: bcmdevtl, dervomsee, hklt0110 and 80 guests
